Valve Spring Compressor for 964
I’m onto my second rebuild and this time I will do the heads (last time was essentially a reseal as the top end had already been done).
What size valve spring compressor tool should I order? Are there any size constraints, features etc required or will a generic size fit? This won’t be used often as I expect two rebuilds will be my limit so I don’t want to go crazy prices if I can avoid it. TIA |
abit off center
I use my same one for the 911 heads
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
