Harpo's Avatar
3.2l ss
Can someone please educate me on what exactly a 3.2L short stroke is and do I want my next build to be one?
Old 08-04-2018, 06:27 AM
BURN-BROS's Avatar
A 3.2SS is simply a 98mm bore with an SC crank (70.4)
I typically give it as an option as any increase in displacement nets you some reward. Also the cost to go to 98mm is pretty reasonable.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 08-04-2018, 08:51 AM
Under the radar
Trackrash's Avatar
If you need new cylinders, it's a no brainer, IMO, to go with the larger bore.
Gordon
'71 911 Coupe 3,0L outlawed
Old 08-06-2018, 05:41 PM
