!973 rebuild
I am rebuilding a 1973 911S motor using weber carbs. I have moved up to 2.8 pistons and cylinders but have changed the cams to the T cam #911 105 142 OR and 911 105 141 OR. I am trying to now doing the cam timing but can not find my 1973
Tech. Spec Book. Can some one out there give me an idea of what the
Adjustment Values and Ideal Value should be so I can get this baby running.
Not sure if the increase in piston sizes will effect this setting. Thx., Bob
Old 09-07-2018, 11:25 AM
What I am trying to find is my dial indicator reading I need to set my cam timing.
I have set the pully at the Z1 mark and I have the dot on each cam pointing straight up.
The dial indicator is mounted on the shoulder of the #1 intake valve spring retainer and is set at zero. The sprocket pin is in place and the chains slack has all been removed. When I rotate the motor clock wise for a short distance the dial indicator will begin to move. My question is " at what setting do I stop at??? Once I know this number I will stop. I will then remove the sprocket pin and move the pully back to the Z1 mark and replace the sprocket pin in the new hole that will except it. Left bank will then be timed and I will then move to the right bank.
Old 09-07-2018, 01:22 PM
Daugaard's Avatar
cam timing
why T cams in a S engine?
I only have the timing for 2,7 S cams: left 911.143.00 & right 911.144.00
0,40 - 0,54 mm
Daugaard
Old 09-07-2018, 02:17 PM
Daugaard's Avatar
911 105 143 OR and 911 105 144 OR
Daugaard
Old 09-07-2018, 02:18 PM
Thanks very much Daugaard….I did not have the money to buy S cams and I thought that that I might get a little more low end torque with the Ts. Originally I rebuilt a 2.4 S in 1985 with 2.8 pistons and cyl. Blew that motor up and did not have the time until now to rebuild. Sold the S cams for big bucks in 1987. All I had left was an extra set of T cams. Could not find anyone to trade cams with me.
Old 09-07-2018, 04:50 PM
Functionista
manbridge 74's Avatar
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 09-07-2018, 08:32 PM
Thanks Jeff very much appreciated !!!
Old 09-08-2018, 05:13 AM
Daugaard's Avatar
Bob the number you have on the cams are for 74-75 2,7 150 hp.
the timing numbers for those cams are diffrent from all up to 73'
If you use the settings Jeff have your exhaust valve will touch the pistons.
You have to find the exact timing for the numbers on the cams.
Daugaard
Old 09-08-2018, 01:56 PM
Daugaard's Avatar
Look for CIS cams settings.
Camshaft Timing on '74 2.7 CIS
Daugaard
Old 09-08-2018, 02:09 PM
Those cams were also used on the 1973.5 T CIS engine.
Here is a copy of the spec book settings for the 72-73 model years. Although I am not sure that the stock settings would be the best choice for this unusual combination.
Tom Butler
1973 RSR Clone
1970 911E
914-6 GT Recreation in Process
Old 09-10-2018, 04:18 AM
Under the radar
Trackrash's Avatar
I have some real T cams from a '70 laying around. Let me know if that is some thing you could use. They could be reground to E specs. A nice cam for your motor.
Gordon
'71 911 Coupe 3,0L outlawed
Old 09-10-2018, 12:27 PM
