-   -   3.0 to 3.2 SS upgrade (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1007976-3-0-3-2-ss-upgrade.html)
fred cook 09-29-2018 07:22 PM
Where............
Originally Posted by plexiform (Post 10199561)
Where did you get this done for $12k?
In my shop! The $10 - $12K was for parts and a valve freshening on the cylinder heads. I provided all the labor at no cost to the owner, me! Many years ago, I worked as a mechanic for about 3 years. Most of that time was spent building stock, hot street and race engines. Digging into a 911 engine was not all that scary!
Harpo 10-21-2018 06:42 AM
Any ideas what a set of 3.2L (95mm) cylinders go for? It looks like it will be just $1400 to get them bored out to 98mm and replated.
fred cook 10-21-2018 08:18 AM
Cost of cylinders...........
Actually, $1400 isn't too bad. A new set of cylinders will likely cost in the $3K to $4K range! I used the 100mm KN Engineering "slip fit" cylinders that were right at $4K! This is a case of "you get what you pay for"!
Josh D 10-22-2018 02:42 PM
They used to be about $400 for a used set, but I've seen prices climb to the $5-$600 range recently. At least that's what folks are asking.
gbutler911 10-26-2018 09:20 PM
Broken Head Studs
I just bought an SC that has broken head studs I believe. It's from an 83 and has engine number 64D2571. I have pictures from the seller that show it underwent a rebuild several years ago but no documentation what was actually done. My ultimate goal for the car does not involve this engine so I'm trying to evaluate selling as a core vs. rebuilding and selling it. Can you give me any guidance? Thanks!
plexiform 10-26-2018 09:30 PM
Nice!
jamesjedi 10-28-2018 03:29 PM
Just a thought on "There is no replacement for dispalcement".
Your car/engine is about 40 years old. If you want super fast - sell what you have and buy a newer car.
Bigger and faster is not always better. These cars have tremendous character. They are old. That said, being old is part of their charm.
Have you ever seen a track prepared early 911 or Alfa Romeo GTV? Would you really care about their displacent?
