Uncertifiable!!!
1. Done. 2. I have a two-wire Bosch IAC. Does not matter which way it’s wired. Works fine either way-good steady idle with or without IAC operating. In my case IAC is primarily used to catch motor on desceleration. 3. See 2 above. 4. See 2 above. All I want to achieve is a higher idle rpm when A/C is on, so I can have cooler air while in traffic. The tec3r has a programming provision to increase rpm at idle when A/C is on but it does not work or is inadequate for my motor. Electromotive has had it twice for repairs with no improvement. I determined that opening the unused 8mm nipple at the base of the throttle body provides me with the required rpm increase. Hence this thread in a quest to find a suitable normally closed solenoid air valve to open in conjunction with the A/C compressor. Prefer Porsche, but if not, some other manufacturer.. My Pierburg valve has not yet arrived. Anxious to test it. Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
