Nux Nux is offline
Nux's Avatar
Can you ID this engine?
Supposed to be a 3.2, but I simply can't decode this engine number - any ideas?
Engine number 961057
Old 11-29-2018, 01:03 PM
Blurry picture, but isn't that 930/21 ? 84 Carrera
Old 11-29-2018, 02:48 PM
The number is
More like a pre 68
Bruce
Old 11-29-2018, 03:52 PM
Under the radar
Trackrash's Avatar
Those stars surrounding the engine number look suspect. Looks to be restamped.
Gordon
'71 911 Coupe 3,0L outlawed
Old 11-29-2018, 04:39 PM
Serial number corresponds to 67S engine, type should be 901/02.
andy
Old 11-29-2018, 05:21 PM
gearhead
Look at the casting numbers on the case halves. 901 or 930 as first three will clear up a lot.
Old 11-29-2018, 07:10 PM
Nux Nux is offline
Nux's Avatar
Indeed yes
Why the odd engine number? Re-stamped?
I'll get some pics of the casting numbers. Think its a 930 case
Old 11-29-2018, 07:56 PM
gearhead
Appears restamped serial number.
Old 11-29-2018, 08:01 PM
djpateman's Avatar
Definitely a faked serial #. As stated 961057 is a 1967 911S engine serial; however it is stamped in the wrong place. The early aluminum cases have the # stamped facing the rear not to the right, and also have a build # stamped under the type #. The stamped type # here is a clue to the original engine case, but what is within can only be determined by a teardown.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 12-17-2018, 05:11 AM
Ora Ora is offline
Banned
Re-stamped, no good., Sam.
Old 12-27-2018, 02:16 PM
Walt Fricke's Avatar
Not necessarily no good. I've got a sand cast case race motor with non-matching case halves. Whoever did the machine work did a good job - everything lines up and measures up from what I can tell. Ran great until I rebuilt it, when some gremlin (unrelated to any geometry) struck.
No good for concours/purity/etc. But otherwise might be a fine engine/case.
Do what Matt suggested and let the forum know what the casting numbers are. My guess is it will be 930.
If it is 930, pull the clutch and see if it is a 6 or a 9 bolt crank. A 6 would be good, as those are rather rare.
Old 12-27-2018, 04:50 PM
