DSPTurtle's Avatar
Mag welding
Is anyone doing mag welding nowadays? I need a few fan shrouds repaired. So far I have had no luck with the usual suspects.
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 12-18-2018, 07:48 AM
It's a 914 ...
stownsen914's Avatar
Try mb911 here on the forum. He is an experienced fabricator, and I believe he can repair mag fan shrouds.
Scott
Old 12-18-2018, 08:25 AM
DSPTurtle's Avatar
Scott
Thanks, just sent him a message!
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 12-18-2018, 08:37 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
won't magnesium burn (ignite) if it gets hot enough...like when welded?
Chris
Old 01-02-2019, 08:51 AM
The 9 Store
Ben/MB911 has done mag fans, shrouds, 3.2 manifolds and 915 trans cases for me. Saved some important parts for way less than replacement cost. He is a pro. He also does stainless steel and aluminum.
All used parts sold as is.
Old 01-02-2019, 05:18 PM
Walt Fricke's Avatar
Magnesium burning
I once made a bunch of magnesium shavings from a junk piece, put them in a pan, and added a flame. With some effort they did burn, though not quickly or sort of explosively. The bulk of our mag parts (and maybe the alloy?)seems to preclude them burning in the kinds of fires we tend to see in and around our 911s.
img]http://forums.pelicanparts.com/uploads26/mag_shavings1546478351.JPG[/img]
I once had the hole in a case half caused by a wayward rod welded up and remachined - worked fine. The fan housing looks like it might be trickier (nothing to machine when done?), but at least it isn't a rotating part, and there won't be a flash fire.
Beyond the DIY abilities of a guy like me with only a small MIG, though.[
Old 01-02-2019, 05:23 PM
Cobalt's Avatar
Mag for the most part is very stable and takes a lot to ignite unless in powder form. If it ignites you want to smother it with sand or a class D fire extinguisher. You never want to use water and don't disturb it once covered otherwise it will reignite once oxygen is reintroduced. Do remember they use raw mag powder in fireworks and in powder form will ignite and spread very quickly.
The trick to welding mag is preheating it to around 500+ degrees prior to welding. You will want to grind away any corroded metal and V grove it prior to welding.
I used to do this all the time but haven't since I retired and no longer have the equipment.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS,
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others
Old 01-05-2019, 05:42 AM
7.0:1 > 11.3:1 > 7.0:1
30 plus years of tig and carpel tunnel issues to show for it. Cobalt, what filler rod to use? Will parent material work in its place?
Old 01-05-2019, 09:18 AM
I had a similar need for a 914 transmission case. I called the local junior college and spoke with the welding teacher there. He gave me two recommendations for local guys. One answered his phone and did exactly what I needed for $80.
Andy Brian
Old 01-05-2019, 03:26 PM
Puny Bird
Mark Henry's Avatar
I know for sure he repairs fans for a couple of the well known shops, he was doing a big run on them not long ago.
He also makes beautiful 914/6 SS header/heat exchangers and a bunch of other 914 parts.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 01-05-2019, 04:42 PM
Cobalt's Avatar
I don't know the specific alloy they used and in most cases you could get away with AZ101 filler rod but since most of my parts were made from AZ91 or AZ92 I would cut strips of material from ingot as filler.
Although it can be welded a fan housing is one thing a case is another. Welding isn't as much an issue as strength. You do kill the temper when welding so although the material is solid it should be done prior to heat treatment. Usually when making cast parts that will have subsequent welding processes they are supplied in a T4 or T5 condition and then aged to T6 after the welding is done or all welding is done prior to any heat treatment processing.
The issue is how long will the weld last if the parts aren't reprocessed to T6 condition which isn't easy to do when tight tolerances are involved. At least mag is best when air cooled vs aluminum which gets a liquid quench.
Old 01-05-2019, 09:29 PM
The 9 Store
Our in house welder has repaired many a 3.6 case where they commonly crack. Nothing to special, just aluminum welding done by a pro. You can talk all day about how to or how not to or take it to a pro and get it done.
Old 01-06-2019, 07:27 PM
Cobalt's Avatar
Aluminum is very different than Magnesium
Old 01-07-2019, 05:00 AM
The 9 Store
Yes, I agree. Our guy doesn't do Mag, that's why I send that stuff to Ben. It just takes the right guy using the right process. Mag welding has been done for ages. Porsche even welded up a mag 917 chassis. I don't know if it was ever raced.
Old 01-07-2019, 05:22 AM
Cobalt's Avatar
I did it for nearly 30 years myself. You couldn't tell it was done even after radiographic inspection however it doesn't change the fact that both aluminum and magnesium will loose their temper when welded. Tensile strength will be seriously diminished.
Old 01-07-2019, 05:50 AM
DSPTurtle's Avatar
Kickass repair by MB911. Thanks to all you guys for your help.
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 01-22-2019, 04:14 PM
It's a 914 ...
A few magnesium framed 917s raced. I have it in my memory that the accident in a 917/10 that cut short Mark Donohue's 1972 season was a mag-framed car, but I'm not sure about that part.
Old 01-22-2019, 06:24 PM
Cobalt's Avatar
Not the prettiest weld I have ever seen but won't be seen and will do the job.
Old 01-23-2019, 05:12 AM
DSPTurtle's Avatar
Looks pretty pretty from this angle.
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 01-23-2019, 06:23 AM
Cobalt's Avatar
Agreed and in this case that is all that counts.
Old 01-23-2019, 04:09 PM
