Very glad you came to acceptance early on! Wonder what kind of rod bearing clearances were there initially, and what type of oil? Did any of the other rods look like they were about to go bye bye?
No physical quantity completely explains its own existence
Old 12-28-2018, 07:13 AM
Whoever built the engine into a 3.3 used FAR too much #574 and that may have contributed to the bearing failure.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-28-2018, 08:43 AM
smarens's Avatar
Steve,
-what makes you think excessive #574? Not questioning your expertise, I'm still a rookie and am also in the middle of rebuild, not trying to high-jack, I think may people would like to hear details from you
thanks
+1 for the excellent photography on this post also
1975 914 1.8l
1979 911SC Targa - In Restoration
1972 Pantera
Dune Buggy Dual Port 1835cc
1980 911SC Targa - Driver/Winter Project
Old 12-28-2018, 05:52 PM
Originally Posted by smarens View Post
Steve,
thanks
My guess is by looking at the squeeze out on the heads from under the camshaft carrier? But then that cannot be 574.. if it was, it would have been wiped away right? (only sets in absence of oxygen)
Old 12-28-2018, 06:26 PM
Nux Nux is offline
Nux's Avatar
The wedge shaped Max Moritz style piston were specifically designed for single plug.
Is it not easy and relatively cheap to get new pistons with higher compression and correct domes to accommodate your new twin plug?
Old 12-29-2018, 05:23 AM
VFR750's Avatar
I think the amount of 574 on the case halves.
Without data other than the excess 574 on the threads, there may have been other locations with similar excess that broke loose. Did you have a picture of the other side of the case? Maybe that had more evidence of excessive squeeze out on the inside.
Oil is not air, so wet 574 should cure. 574 also cures with time and heat it seems on my outside cam cover edges.
Old 12-29-2018, 03:07 PM
Great question. Piston were essentially new so didn't want to get new but you make a good point.
You are correct that they are designed for single plug but dual plug will still have added benefits from what I understand.
Does anyone think that the wedge-dome design somehow will be 'bad' with the dual plug setup??
Old 12-29-2018, 03:30 PM
Here are other pictures of the case.
Old 12-29-2018, 03:33 PM
Things are starting to go back together..........
Old 12-29-2018, 03:52 PM
Here's the crank/rods in place ...........
Old 12-29-2018, 03:55 PM
Cylinders and jugs coming together........piston rings getting hand lapped like the rails on my 1911 LOL......
Old 12-29-2018, 03:57 PM
I love jugs......
Old 12-29-2018, 04:02 PM
Heads and cams are next.......
Old 12-29-2018, 04:05 PM
Pics documenting Tim's level of OCD.......brushing away excess sealant......
Old 12-29-2018, 04:15 PM
Closeups of pistons/rings/jugs......
Old 12-29-2018, 04:23 PM
VFR750's Avatar
This is so fun to see. Engine parts being assembled.
Old 12-30-2018, 05:31 AM
Pretty nice rack there sir.
Old 12-30-2018, 05:38 AM
Love the look of all the metal parts. Were they all vapor blasted? If not, how did they get that clean?
Thanks, Rick
Old 01-05-2019, 03:15 AM
Thanks, Rick
Correct. Vapor blasted.
Old 01-05-2019, 07:58 PM
shbop's Avatar
Looking good there gwag. Very nice. Every time I see one of these threads, it has me re-thinking building the 3.0 in the corner of my garage, but I think I've spoiled myself with displacement. I built a 3.6 for my 81', and it's a powerhouse. I built a euro 3.3 turbo before that, and was blown away by the power it delivered. For those out there who have been down this road: will a 3.0, modded to 3.2SS with good injection, come close to the power from either of the above mentioned two? I'm thinking I've spoiled myself, and need to give-up on the idea of building a 3.2ss, and search for another 3.6.
Jon
Old 01-06-2019, 03:11 PM
