Here are some updates.......engine coming together.......going to dyno soon........
Going with carbon fiber shroud........
Oil coolers replaced.........
Engine assembled.........
Engine in !!!!
Really nice - I wish my engine builder took note in terms of pics and updates; it appeared to
Be a chore to him to let his customer know what was going on... I’ve not seen those pistons before, nice option
Shirish 1987 Carrera, Granite Green |
Sure do enjoy Steven's tools.
Jon |
1987 Porsche 911 Carrera Coupe |
I decided to stay single plug with the same 3.4 Mahle Max Moritz design 9.8 compression P&C (my 3.2 pistons had valve slap on them and were alusil). But also going with 964 cams, Aasco springs and retainters for higher redline. BTW... REALLY love these pics. I wish someone would just create a video of EVERYTHING they do to build the engine.
https://m.youtube.com/watch?v=HqTJ2lgVEKY, if the link doesn’t work search “The Canary Files” this guys documented his entire engine rebuild on YouTube I’ll be doing the same when I rebuild my 964 engine later this year when I finally get my garage built |
Trackrat - The legendary Carroll Smith believed locking tabs don't work. He suggested "prevailing torque" nuts. I suspect nylocs, though less positive, would do.
I'd have to look at the other case half to be sure, but maybe the nut couldn't come all the way off anyway when the case is together? Only the upper nut is subject to tension with the pump turning. The force would vary with RPM, which is a minus for the nut staying put, but maybe not really enough to loosen a properly torqued regular nut? One doesn't hear about these nuts coming loose, though. |
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
What do you think Smith thinks about the ability of a wave washer to add anything significant to the stretch of a fastener? To be sure, Porsche used them in some applications, like under all those nuts holding the cam carrier onto the heads.
Loctite maybe, though if Smith is right about the tabs, with the standard torque for an 8mm stud, maybe any flat washer is fine with a standard nut. The washer keeps the nut from gouging the aluminum of the pump. |
Location: behind the redwood curtain, (humboldt county) california
Cross threading....
"Cross threading is almost as good as Locktight"
Anon |
Amazing thread .....
Call 911
Well done! Great photographic detail.
Dave Kirk My Porsche restoreth my soul. |
what size/part number are those Bosch spark plugs you're using there sir
No physical quantity completely explains its own existence |
Schleprock
Nuts in that picture of the oil pump installed are actually nyloc style like those used on the valve covers. Like Walt said, the "top-lock" prevailing torque nuts are a better choice here. Nyloc don't provide a lot of locking effect
Kevin L '86 Carrera "Larry" |
Under the radar
Interesting choice to use nylocks inside the motor. Porsche never did that, and there are mechanics that recommend against it. Loctite would probably do the trick. How can locking tabs fail anyway?
