Early 911 whine.
Trying to track a possibly excessive whine from my 1000 mile old build.
I have heard other 911s with this much whine but just as many without.( I am also deaf in one ear.)
2.4 with 2.2S pistons on a sandcast 67 case S cams and MFI.
Disconnecting fan belt eliminates alt fan as a source.
Using a machete as a stethoscope I isolated the whine on revving to the outboard cam sprockets.
Can sprocket alignment cause this? new chain,new sprockets, new pressure fed tens.
I measured per Waynes book for alum case.
Is this something that improves with miles?
I use brad penn oil and have used aeroshell 40 with zinc.
Old 01-11-2019, 08:27 AM
Chain alignment, depending on the degree of misalignment, can generate noise. Without hearing it for myself, its difficult to offer anything more specific. Intermediate shaft gears can also generate a whine if there is a problem
It will not get better over time so this is something to recheck.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 01-11-2019, 08:31 AM
Under the radar
Trackrash's Avatar
My motor started to whine. Sounded like a bad alternator bearing. Turned out to be a collapsed tensioner.
Gordon
'71 911 Coupe 3,0L outlawed
Old 01-11-2019, 06:52 PM
Thanks guys! I am going to check it out.
Old 01-18-2019, 08:25 AM
