zman911's Avatar
Engine lowered but wont remove
I bought the book (101)...good stuff! I am attempting to remove the engine in my 71 911T to fix the leaks.
I now have everything disconnected.(I checked at least 3 times)I lowered the engine, but the engine will not roll away from the transmission.(Im doing engine only first) Do I need to get a real man out to help force this or should is back out relativly easy?
Thanks in advance....great place!
Old 02-11-2003, 06:01 AM
Super Moderator
cstreit's Avatar
Are you trying to leave the trans attached, or just remove the engine, leaving the trans in place?
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 02-11-2003, 06:48 AM
Irrationally exuberant
ChrisBennet's Avatar
I'm not familiar with the pre-72 transmissions but my guess is the the clutch fork is hung up on the release bearing.
Why do people insist on dropping the engine alone? It is much easier to drop engine and transmission together and you don't run the risk of hanging the transmission by the shifter shaft and wrecking the seal. Short of a pro beating the book rate or a mid-race engine R&R I see no reason to remove the engine without the transmission.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-11-2003, 06:50 AM
zman911's Avatar
I am was leaving the transmission attached to the car...only because that is what I was reading in the book. Should I reattach a few of the bolts and try to take it all out?
Old 02-11-2003, 07:00 AM
brandett's Avatar
Most people seems to think its easier to pull the engine with the tranny. Not that much more work, the book mentions what you have to remove in order to do it. The big + will be when you put it back, much easier.
It´s my hobby.
911 SC -82 coupe.
My Project
Old 02-11-2003, 09:32 AM
JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
It is easier to re-attach the tranny out of the car. If all four nuts/barrel nuts are removed from the studs, I would expect that your clutch fork is engaged. Try moving it. I want to re-iterate from experience, it can be difficult to re-attach the tranny when the tranny is still in the vehicle. I know from experience and a sore back. Good thing the wife is a Chiropractor...
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 02-11-2003, 10:12 AM
zman911's Avatar
Great advice....Im going to drop back and reattach the transmission and then remove it all. I should have thought of that but glad I ask. I took me about 2 hours to get the hidden starter bolt out I cant imagine trying to piece the 2 together under the car.
Thanks to all!!
Old 02-11-2003, 11:11 AM
Engine Drop
I strongly recommend that you use an engine dolly instead of a floor jack. There are two schools of thought about DIY engine drop one using a floor jack and others use wooden engine dolly.
Floor jacks are good for VW engines (lighter) but for bigger and heavier engines, the dolly makes the job a lot easier. These are two different styles of removing the engine from the car and you'll find later which is better. Just my $0.02......
Old 02-12-2003, 08:36 PM
Senior Member
john_colasante's Avatar
I told Wayne to add a special note about '70-'71 cars in his book but he didn't bother. Too bad. These cars are special in that the clutch TOB has to be rotated before it disengages from the fork - it's the "pull type" clutch.
John Colasante
johnc911@gmail.com
www.cupcar.net
Old 02-12-2003, 09:43 PM
Navin Johnson
TimT's Avatar
John is correct in that you have to release the T/O bearing from the shift fork.... 3 small bolts and some spacers...... or someone with a strong screwdriver.
'69 911 GT-5
'75 914 GT-3
and others
Old 02-13-2003, 06:44 PM
zman911's Avatar
Great info and perfect timing!! Im taking off early this afternoon to work on it.
Thanks!!
Old 02-14-2003, 05:16 AM
JTO JTO is offline
I've pulled my engine four times in the last six months dealing with my clutch issue, engine rebuild, etc. I had to find a more secure way of removing the engine than the floor jack. I bought a ATV jack that consists of two long rubber coverd plates that are the same width as the heater boxes on my SSIs. The ATV jack has a lift of 32". This device allows me to lower the engine in complete security with no fear of the motor tipping off a floor jack. It has allowed me to pulle the engine or engine and tranny with a lot more confidence and control. Its very stable.
Troy
Troy
Past: 1975 911S Silver Anniversary-rebuilt and sublime.
Past: 1988 Carrera-backdated with a 3.6 and all the goodies.
Present: 2011 GMC 2500HD with the 6.0 & 4x4!, 2004 Toyota Sequoia (wife's)
Old 02-17-2003, 12:25 PM
JTO - Where did you get your ATV jack? I was looking at Sears but their cycle/ATV appeared not to lift 32-inches and a handle gets in the way as well.
Antares
fatnwide
Old 02-22-2003, 09:20 PM
zman911's Avatar
JTO
Great idea on the jack...where did you get it?
Old 02-25-2003, 01:37 PM
No Expert
jgparker's Avatar
Porsche Crest Long Frame Jack
Harbor Freight has a great 2 ton long frame jack, if you pull you 911 engine a lot. It has a solid 32" of lift, and it usually costs $100 if you wait for a sale. Add in the Pelican Engine/Transmission Jack Adapter, and you can pull the E/T without removing your Webbers, and without a friend. See Picture. I've pulled mine about 20 times in the last 5 years, and I have to say I prefer pulling the E/T together. See Picture.
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 02-25-2003, 03:07 PM
zman911's Avatar
That jack set up looks sweet!!
I FINALLY at got my engine AND transmission removed thanks to all the good advice. This was my virgin drop and I would absolutly recommend removing both at the same time....that would have save me 2 weekends and about 2 cases of beer.
Old 02-26-2003, 04:55 AM
Certified Pre-Owned
BGCarrera32's Avatar
Wink
Yeah, til' it gets bumped into...
'84 Carrera Coupe
Old 03-05-2003, 07:51 AM
zman911's Avatar
Yeah I agree and thought about that too. Im going with a stand.
Old 03-05-2003, 08:04 AM
No Expert
jgparker's Avatar
I know it's hard to believe, but it is actually very stable with the adapter in place. I wouldn't want to pull it down the street this way, but you would have to force it to make it come off the jack. See picture.
Old 03-05-2003, 04:14 PM
Banned
snowman's Avatar
I commend Wayne or anyone else who has the time and time and time and sweat to put into what it takes to make a book of any kind.
If it were not for people like this we would be in the dark ages.
Old 03-09-2003, 01:18 AM
