911 rockers wear level at break-in period
Hi all.
I have a question regarding wear level during break-in of rockers and camshafts. Is it likely that the rocker in the picture eventually will wear and mate perfect to new camshaft? Pictures taken after 20 minuttes initial break-in at 2000rpm’s with DRIVEN break-in oil containing 2400ppm ZDDP. Rockers grinded at a very solid and reputable Porsche workshop.
Wondering what was the reason for the tear down after 20 minutes of runtime?
Inspection to see the development of the break-in process on both camshafts and rockers. Last edited by Classic 911; 10-12-2020 at 03:12 PM.. |
What do the cams look like?
What sort of lube did you dribble on the cam lobes before you installed the rockers?
Did you wipe off all the oil on that cam lobe before you took a picture of it? |
Was there a coating on the cams to begin with? Does your fingernail catch any of the markings?
Matt B '73 911E |
Drive the car for 10,000 miles and find out.
72 Carrera RS replica, Spec 911 racer |
Where is the cam from. I have heard WebCam has had some issues with lobes ground on an angle....
Does not look nice. Since it is all apart may as well find some different rockers and cams before reassembly. Sucks, but sh%t happens.
Talk to your vendors. |
Looks to me like contaminated oil or rocker bushing issue. |
