Stranger on the Internet
patkeefe's Avatar
2.7 Street Engine
Hi all,
I have a 2.7 engine that was going to go into the (since departed) 914 racer. It has never been final assembled...9.6:1 JE Pistons, single plug, EFI, rebuild cylinder heads. Newly rebuilt 915 with LSD and 8:31.
I have S cams in it now, but am thinking that maybe an E grind would be a better street cam. I have the S cams in, brand new Web Cam, not yet timed. It would be an easy matter to swap these out now. I am assuming that the MFI S cam profile would be the most extreme as related to any clearance issues with the valves and pistons, which I have already verified as non-issues.
I am soliciting anyone's two cents worth on cam profiles.
TIA
Pat
Patrick E. Keefe
78 SC
Old 06-23-2019, 06:50 PM
IMHO, S cams are the way to go in a 2.7... especially with that compression ratio.
Old 06-23-2019, 07:26 PM
If you want a wider torque range, I'd use either Mod-S cams or Solex ones.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 06-24-2019, 09:31 AM
Mod-S or DC40! Makes for superb driving single plug cars
No physical quantity completely explains its own existence
Old 06-24-2019, 10:31 AM
tk_008's Avatar
I have a 2.7 with single plugs (but MSD ignition) PMO 46's and E cams. It starts to pull from 3000 and isn't finished by a very conservative 6200 redline. Works great!
Old 06-24-2019, 10:34 AM
Vintage Owner
Jack Stands's Avatar
The S cams Henry Schmidt put in my 2.7 were ideal. That was with the 8.5:1 RS P/C set and 40mm Weber carbs.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 06-24-2019, 01:04 PM
Under the radar
Trackrash's Avatar
I think you would regret going with E cams. With 9.5 CR and MFI, the S cams should be very streetable.
Gordon
'71 911 Coupe 3,0L outlawed
Old 06-24-2019, 01:56 PM
