jamesjedi's Avatar
Alternative Cylinder Hold Down Nuts?
Hi,
Is there an "off the shelf" alternative to buying the Stomski Cylinder Hold Down Nuts?
They are just M10 (I think?) for an SC motor.
Cheers and thanks!
Old 02-26-2019, 02:05 PM
I 3D printed some for myself, a lot less expensive that route.
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 02-26-2019, 02:52 PM
I made some out of aluminum on a lathe. Took a couple hours. If your stock it’s M10 1.5 if you have supertec they use M10 fine thread which is different so be aware.
Old 02-26-2019, 03:06 PM
Slippery Slope Expert
Steam Driver's Avatar
Cut PVC pipe spacers of appropriate length, use regular head nuts with a washer underneath; works great, REAL cheap!
“As new technologies become indistinguishable from magic, and I can no longer tinker, the magic goes away for me.”
Old 02-26-2019, 03:27 PM
jamesjedi's Avatar
Thanks for the replies.
I’m guessing sockets would not work?
Sounds like there could be many options.
Thanks again.
Old 02-26-2019, 04:42 PM
You can also triple stack the barrel nuts for the ultimate free99 tool:
Thread the first 2 all the way on and the third one cinches the group down.
-Jayson
IG: Signature_911
Old 02-26-2019, 04:58 PM
jamesjedi's Avatar
That one sounds very easy. I will most likely do it. Cheers and thanks!
Old 02-26-2019, 06:19 PM
Old 02-26-2019, 06:30 PM
jamesjedi's Avatar
Thanks Bill. Sockets will work.
Old 02-27-2019, 05:37 AM
