Originally Posted by Raceboy View Post
VEMS plug and play ECU Gets you more hp and also much-much better driveability plus allows you to use whatever injectors or other mods you can ever think of (ITB, turbo, both )
Check out www.facebook.com/vemsporsche
VEMS for Porsche
Could you send me a link on the documentation for the 911 3.2 version of this product?
I tried looking for it on your website, but found a non-English page and got lost.
I just want to read up on how you install it, configure it, etc...
THANKS!
1987 Porsche 911 Carrera Coupe
Old 03-12-2019, 06:56 AM
Turbonut
Raceboy's Avatar
If you PM me your email I can send you installation instructions.
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 03-13-2019, 11:44 PM
VEMS for Porsche
Peeps,
What do you notice in way of improvement when going from batch fire injection like a standard 3.2 in your P'nP setup to full sequential injection by adding a supplementary injection harness to wire each injector separately?
Is the P'nP setup shown 1250 euros plus postage?
Peter
Old 03-14-2019, 02:42 AM
Turbonut
Raceboy's Avatar
Hi!
Yea, it is 1250 euros but shipped. No additional postage cost.
There's not much benefit unless one uses big injectors. Then it is possible to time injection as pulses are short enough (otherwise pulse is so long that it does not matter).
Additonal harness only is not enough, you would need cam sync sensor as well (but it is possible, VEMS has up to 5 trigger inputs).
Without cam sync you can still fire injectors sequentially but the injection is not timed.
Old 03-14-2019, 05:05 AM
