73E piston cylinder question
I am putting back together a 73E motor and I am having second thoughts of using the P/C's My piston cylinder clearance is pushing .004 to .005. Question: I have a set of NOS porsche 2.4T first oversize pistons. Could I use these if I bore my cylinders. I realize the compression will be .5 point lower, but maybe that will be better than having that large P/C gap? Any thoughts?
thanks, Mike |
Author of "101 Projects"
You'd have to bore and have your cylinders replated with Nikasil. I doubt it would be cheaper than a new set of P&Cs...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
I thought the 2.4 weren't nicasil just steel?? What do you think about the .004 to .005 clearance???
Thanks |
the 2.4 t cylinders where cast. the price of those e piston and cylinders are quite scary. t and s 's are cheaper.
72 911t grey/black mine 74 914 2.0 black/ tan hers 02 g500 black/black womanproof 01 f250 psd dirty the mule 60 correct craft starflite cool 69 correct craft torino hauls butt 72 correct craft ski nautique fun 66 vw 1500s will finish someday |
Banned
If the cylinders are just cast iron, get them bored and honed. I do not know the answer if they are Ni coated. But if they are not go with it.
