Converted to COPs, how to use timing light?
As part of my 930 FrankenCIS on steroids I've converted to COPs.
Now I have the car starting and idling reliably I need to fix my #1 tooth angle (I'm using a 60-2 flywheel). I purchased an adapter from Amazon, which of course is useless lol Anyone got any ideas on how to get a timing light to work? I'm using in a wasted spark setup so I'll actually connect on #4 since it's easier to get to than #1 under my intercooler. I can't imagine any issues with that, is there anything I've missed?
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan '14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button! |
use a old spark plug wire... put plug end on plug, and use a piece of 1/4 rod/or bolt or something for COP to wire... Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
I have Denso COP set up on one of my cars (not a Porsche) with a Haltech ECU and factory cam angle sensor. All I do is hook up the timing light connector that you would normally put on the spark plug lead to to wires coming out of the COP connector. Of course you still have to supply power/earth to the timing light for it to function. Strobes perfectly and works a treat.
Turbonut
Most timing lights work on logical level also. With VAG coils and my noname timing lights it picks up logical signal without any issue.
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet http://www.facebook.com/vemsporsche |
I'll try it on the signal wires first, but these are "smart coils" with the igniter in them so the signals are logic level.
Its a Sears timing light from, whew, early 80's. Back when Sears had decent tools.
I'm starting to wish I would've just gone COP from the jump but wanted to stray away from added complexity with getting it started on the standalone.
Did you convert for the hell of it or were you getting spark blow-out? This'll be my second time now upping the boost and getting some break up at the top of the pull above 6,000. Solved the misfire last time by switching to different plugs and closing up the gap but not sure how much tighter I'd like to go...
"Frankenstein" - 964 C4 chassis/driveline - 993 widebody/Speedster look - VEMS standalone - twin plug high compression 3.6L N/A engine - 945cc cc/min injectors - Bosch 044 pump - GT45 @ 1bar/14psi - non intercooled/wingless - E85 fuel - turbo inlet water meth inj. - 3.5" exhaust - GT3RS clutch + LWFW |
I'm having a little difficulty visualizing your setup. Are you crank-trigger or is the trigger wheel in the ignition distributor?
All the wasted spark setups I've done have been crank-trigger so you set the timing (ignition map) through a USB interface, computer, etc. You won't be able to set the timing with a regular timing light because of the wasted spark (extra fire). It'd have to be for a 12 cylinder car or something to be able to see it.
'66 11-window VW Bus (Fuel-injecter'd Super-1600, IRS, disk brakes, MB CLK rims) |
I usually use an inline spark checker and just put the inductive clamp around that for COP vehicles.
Just use an extender spark plug cable from the plug to the COP and hook your timing light on the extender cable.
regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Its a crank trigger, my flywheel was cut to 60-2 and using the stock 993 CPS.
