^ Can't wait, thanks as always Neil!
Try not, Do or Do not
As someone who has built hundreds of these engines over the last 40 years, I find your assertion that "proper machine work" is some kind of scam to be offensive. You came to this forum asking advice and dump a load of shyt on those who try to help you. Every single 2.7 mag case with mileage will have line bore issues. The pertinent question is "how much"? I always get a kick out of newbies that have it all figured out.... Good luck to you on your journey to "cheap it out...." There are reasonable compromises but willful blindness is not one of them.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 06-09-2019 at 05:46 AM.. |
Best of luck in your "rebuild"... Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Yeh ok your going to line bore a mag case with a Bridgeport Mill?? That comment alone shows your an idiot. Maybe try a dremel or hole saw.
It was my intention to pull down your pants and paddle your arrogant ass... I guess I hurt your feelings as well......waaaaaa!
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Haha. DpMulvan my Bridgeport mill comment was facetious, a joke. I wouldn't even know how to set one up and it was in no way meant to mimimize the effort some people put into machining our engines for us and if I offended anyone it was not my intention.
It was the equivalent of saying if I needed $7k worth of machine work on my 7R I would throw out the window. Maybe I should've said that in the first place. I actually just got through watching an hour of the School of Automotive Machinists machining a block and heads and am fascinated with the amount of work and measurement and setting up the equipment required. And am thoroughly impressed with the select few magicians who can do the proper machining to make our engines better than when they were new. So my apologies again to anyone I offended especially those with machine shops since I'm about to tear down my 7R for rebuild and will need the services of a good machine shop who knows these cases well. P.s. The dremel idea might just work. Tony |
Arrogance will take you no where.......
Jess, You came to this forum seeking advice for your disassembly problem because you simply could not figure how to fix it. That was a good decision you made. Unfortunately your ignorance and arrogance have dominated your emotion. And started acting like a fool. This was the exact word you described some people you don’t even know. Your reaction to comments and suggestions was some what illogical and uncalled for. It is unfortunate you have been referred as STUPID but you deserve it. Your posts are simply giving a clear picture of your mental ability to comprehend your disillusionment. You got a serious attitude problem. Take a break and just lick your wound. And just focus on your engine rebuild to keep you occupied. Wish you luck. Tony |
Whatever dude ![]() |
Here, I want you to take this free phone ☎️ pass. Call your mommie and tell her you put your big boy pants on and spoke up to that big bad man on pelican. She will be soo proud of you. ![]() |
The end
Thread Tools | |
Rate This Thread | |
