Catorce Oil Filter Console
I was very intrigued by the Catorce filter console in the 'disaster' thread, so I hope my question is appropriate for this forum.
The Catorce website shows this filter console taking the place of the engine mounted oil cooler. Does that mean I need an aftermarket oil cooler somewhere else on the car? Or does it mean that our 911 engines are happy to run WITHOUT the original oil cooler? Sorry if that's a 'newbie' question, but it's not spelled out at the website, so I thought I'd ask. Thanks for the help!
Robert ----------------------------------------- "A man must consider what a rich realm he abdicates when he becomes a conformist." ~ Ralph Waldo Emerson ~ (thanks to Pat Keefe) |
Thanks for the plug on my products. There are a ton of threads on here about the effectiveness of the engine mounted oil cooler - or the lack of effectiveness thereof.
My oil filter console was created for track cars that already had a front mount oil cooler or coolers, and therefore the engine mounted one was redundant. As to the effectiveness of the cooler on a STREET car, I will defer to the more experienced members of this forum, but my gut tells me it does little to nothing. |
Catorce, thanks for your speedy reply!
I suspected that you intended it for cars with a front mounted oil cooler. On a street car, I imagine something like Elephant's wheel well cooler would also suffice. The possibility of running a street car, 'sans cooler,' is also intriguing. I hope others will offer an opinion. From the other thread, I learned a lot about 'upstream and downstream' oil filtration that I'd never considered before. If oil cooling is sufficient or taking place elsewhere, your filtration manifold seems like a 'no-brainer.' BTW: I enjoyed seeing the beautiful work represented on your website.
It's a 914 ...
I run filters in place of the engine mounted cooler on my race cars. All of them predate Catorce's filter console, so I haven't tried his, but it does look like a good product. Note that the factory put filters in this same spot on all its 911 based race cars back in the day.
Catorce - not sure if I asked this previously ... I recall that your filter console has the angle filter mount for additional clearance. Does it have enough room for a large filter like a System 1 and still clear an oil line mounted directly below? Scott |
Yeah my filter has a big angle on it so you can actually remove the filter without contortions. Both the 993 console and the 965 console make for a really hard filter to remove. Of course both of these filters were made with power steering in mind, so I decided to design one without that consideration. Works excellent, lots of them sold already and out there. |
how is the oil line connected ? Do you use an adapter that allows using the stock rubber hose to be used ?
80SC (ex California) |
We are in the process of making an adapter to fit it that accesses the stock S hose so you can use all of your normal oil lines and connect everything. |
