Targa_PB_78_SC
Cooling tin redo round 3 maybe?
After doing my cooling tins twice, I find I might need to revisit
![]() I was not worried about doing the center piece modifications because the word was for post '77 the factory already did. Seems not to be the case for my '78. I assumed maximum contact was desired with the fins on the cylinders. Seems not to be the case. So do '78 SC's need to have the cooling tin modified? Looks to me like figure 5.2 pg 151 in Wanyes book (sheet metal installation para) is without the mods? I have photos of the install on the 1,2,3 side. Looks like I need to get out my tin snips? Photos in next post Last edited by mike sampsel; 08-31-2019 at 11:53 AM.. |
Targa_PB_78_SC
Photos of tin on 1,2,3 side without any modifications made.
![]() ![]() ![]() ![]() I assume after the tin snips modifications (not done in the photos) the cooling tin highlights in red would no longer be present, Last edited by mike sampsel; 08-31-2019 at 12:06 PM.. |
Looks like the center double divider are installed backwards
Bruce |
Targa_PB_78_SC
Hum, this will be easy they said, you can do it they said. LOL
I had them like you suggest, Bruce, but then swapped them thinking I needed to maximize the tin to cylinder fin area. Need to study my thermodynamics text.
Targa_PB_78_SC
So the correct way would be to slide in as the arrow shows?
This tracks with what it shows in Bruce Anderson’s book. No tin snips required. Seems counter intuitive because less tin on the cylinder fins.
Targa_PB_78_SC
Sure enough a more careful view of my before photos shows the way.
(man/dude)
As an aside, I don't think the purpose of the tin is to absorb heat from the fins, but rather control and contain the air flow. So maximum contact with fins is not the point.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
Targa_PB_78_SC
Anyway, I get the air flow, thanks for reinforcing this. And I’m now an expert in tin removal from this exercise and removing head and cam assym to check case/cylinder gasket width (another learning opportunity)! |
(man/dude)
Yeah I've had plenty of learning opportunity too..... in my case, all about wrist pin wire locks.
I'm a few steps behind you...
