anyone in the UK? anyone got the tools for timing?
Looking to rent a dial gauge and z block so I can have a go at timing my 1970 911 for the first time.
Replacing barrels and pistons so I am going to have to re time it and can't find a block and gauge package in stock in the UK.
Dave
Old 09-12-2019, 12:53 PM
Under the radar
Trackrash's Avatar
All you need is a dial indicator with some way, like a magnetic base, to hold it in position. Not expensive, and assuming you will be keeping the car, you will probably need it again. You may even need the dial indicator for other operations on your build.
Gordon
'71 911 Coupe 3,0L outlawed
Old 09-13-2019, 08:34 AM
Walt Fricke's Avatar
These tools aren't expensive, at least not in the US. The digital dial indicator I bought for $75 10 years ago is now about $35. A Z block can't be expensive, lasts forever, and you could make your own if you can weld, have a drill press or just drill, and some taps.
Old 09-13-2019, 03:01 PM
Z-block and dial indicator..........
Dave,
Any luck finding a local guy to lend you the tools? I contacted a British guy who used to live in US near me and now back in UK. Awaiting for his reply and will forward it to you.
Tony
Old 09-14-2019, 06:21 AM
No luck yet mate. I know they aren't expensive but trying to find someone with the Z block has been impossible so far
Old 09-14-2019, 10:15 AM
MBEngineering's Avatar
https://www.pelicanparts.com/More_Info/PELTOLP207.htm?pn=PEL-TOL-P207&bt=Y&fs=0&SVSVSI=911M
Regards mike
1983 911 SC sport, 1982 mini city
Old 09-15-2019, 07:15 AM
sp_cs's Avatar
Ask on impactbumpers.com
Shirish
1987 Carrera, Granite Green
Old 09-15-2019, 08:44 AM
