Nux Nux is offline
Nux's Avatar
Is this case reusable or is it trash?
Otherwise straight and ok 7R case that came with another project. I believe it has sat many years with water in the bottom. Only the sump area is corroded.
Is it usable or at least fixable - or should it go to the eternal Porsche fields?
Old 09-10-2019, 11:09 AM
100000000% trash.
Old 09-10-2019, 11:28 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
At first glance 1000000% trash. However, its just the Sump cover there.
Chris
73 E
Old 09-10-2019, 11:34 AM
Nux Nux is offline
Nux's Avatar
Originally Posted by Catorce View Post
100000000% trash.
yeah was hoping you would chime in here
No point in trying to repair the thing? It's only the sump.......
Old 09-10-2019, 11:41 AM
Mag 2.7 cases are so plentiful I'd just look for another.
Old 09-10-2019, 12:17 PM
lake wales fla
Too bad you are so far away i have a couple of 7r cases i would like to sell
Old 09-10-2019, 12:31 PM
Chris
73 E
Realistically not going to put 20K worth of parts in that case, sump cover or not.
Old 09-10-2019, 12:33 PM
That is caused by water sitting under the oil for a long time. Usually it occurs behind and under the oil pump.
Bruce
Old 09-10-2019, 03:01 PM
The old saying applies here. One man's junk is another's treasure.
Old 09-10-2019, 06:04 PM
The 9 Store
Time to make a coffee table.
All used parts sold as is.
Old 09-10-2019, 06:06 PM
Functionista
manbridge 74's Avatar
Throw it on your next bonfire....
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 09-10-2019, 06:13 PM
Under the radar
Trackrash's Avatar
I was going to do that with my old motor until someone offered me $4K for it.
Gordon
'71 911 Coupe 3,0L outlawed
Old 09-10-2019, 06:14 PM
WOW, I love it! Awesome man cave accessory!
Old 09-10-2019, 06:22 PM
Find your local mag welder and see what he thinks, fix may well be very cheap compared to a replacement case. If nobody noticed, common mag cases are well over $1000 now. Certain engine codes are way, way over that price. What is the engine type?
Of course if you don't need the case, throw it up on ebay, I'm sure somebody will take it for the right price.
Old 09-11-2019, 11:15 AM
Make a floor "LAMP STAND" out of it in upright position engine to allow lights go thru out piston holes with unique lamp shade on top of it. It is great for all others to admire it as an ART form since it may be valuable as it is probably is very RARE indeed for a lamp stand out there It is light weight eng. block.
Just an idea instead of throwing it away...maybe useful for your man garage and always can sell in the future as a rare gem lamp stand Cheers!
Old 09-12-2019, 05:20 PM
Under the radar
Trackrash's Avatar
I was going to offer to take this, then realized it is on the other side of the pond.
Gordon
Old 09-12-2019, 07:27 PM
