Re-use engine case bolts
Hi All, I'm in the middle of a tear down of my -71T engine.
Looking for the engine case through bolts and nuts I frequently see used bolts for sale. Does this mean I can re-use my bolts and just get new nuts?
I'm building a stock T-engine, no big upgrades.
Appreciate all input,
Jörgen Forssling
Gothenburg
SWEDEN
Old 09-24-2019, 12:59 AM
It's a 914 ...
stownsen914's Avatar
I believe it’s typical to reuse both the bolts and nuts for the case through bolts as long as they appear to be in good shape.
Scott
Old 09-24-2019, 06:49 AM
Yes you can reuse them just be sure to use new o rings and lubricate them and be careful so they don’t rip when tightening. If you don’t have o ring lube then I’ve heard of people using Vaseline to coat the o rings so they won’t get damaged when you are tightening the bolts.
The o rings should come in the engine gasket kit
Tony
Old 09-24-2019, 07:28 AM
(man/dude)
Jonny042's Avatar
The design changed over the years so maybe people update and sell off the old ones? As far as I know they went from coarse thread to fine at some point.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 09-24-2019, 08:31 AM
They went to fine thread with the 3.0. If I’m building a mag motor, I’ll try to find a set of fine thread to use as the torque adjustment is more concise and adjusts to the second torque better.
I have several sets of coarse threads available.
Bruce
Old 09-24-2019, 10:21 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
there are hardware kits available that provide all new nuts, bolts and washers. Dont remember it it includes the through case bolts. See no reason they could not be reused if cleaned up.
Chris
Old 09-24-2019, 12:05 PM
Thanks all for your input!
//Jörgen
Old 09-25-2019, 12:16 PM
targa72e's Avatar
The washers also changed with the use of Aluminum cylinders. The later washers have a beveled edge. With the early flat washers the cylinders will hit the washers and not seat into the case.
john
Old 09-26-2019, 12:36 PM
