engine support on stand
I have my turbo engine out and want to hang it on an engine stand,I've been told the 4 studs that mount the trans to the block will support the weight of the engine on an engine stand is this fact?? thank you
Old 03-26-2003, 02:07 PM
brandett's Avatar
You are getting into a dangerous discussion
Opinions vary..
Check this thread
It΄s my hobby.
911 SC -82 coupe.
My Project
Old 03-26-2003, 11:52 PM
Author of "101 Projects"
Wayne 962's Avatar
As mentioned previously, I just heard the other day about an engine that broke on the 4-prong stands. Particular with a 911 Turbo engine (which is much heavier than a regular 911 engine), I would not go with anything but the official five-pronged stand.
-Wayne
Old 03-27-2003, 01:07 AM
Wayne, did the yoke itself break or did the threads pull out of the block? I'm afraid that even using the 5 prong yoke the aluminum block threads would not hold the studs or bolts? The studs only screw in about an inch?
Old 03-27-2003, 07:58 AM
turbos definitely can be chancy in an engine stand. if nothing else, fab up a support bar between engine and floor. i had a mag case engine pull the top stud out once, which also broke the bottom stud off on the way down. just missed my foot.
206 637 4071
Old 03-27-2003, 08:17 AM
Forced Induction Junkie
WERK I's Avatar
I currently have the turbo engine on the 5 yoke/engine stand. The engine had the CIS and heat exchangers when it was secured to the yoke. At that point, it is really no heavier than a 3.6 or 3.2 litre engine.
I say go for it.
Dave
85 factory slant turbo
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 03-27-2003, 06:45 PM
