Hbrand
hbrand's Avatar
Cylinder heads before and after
This is my second set of cylinder heads rebuild by
JB Racing in Tavares, Florida.
They have all the necessary tools and know how.
Price was $ 1400.- with new guides, seals, some new studs and all the labor.
Blasted and all.
Cheers
1982 Porsche 911SC Euro
1969 Mercedes 280SL
1956 Austin Healey 3x
Old 10-17-2019, 01:53 PM
Any new seats or valves required?
Old 10-17-2019, 02:54 PM
Cgarr on here does this too... roughly half that price...
Old 10-17-2019, 05:02 PM
Jeff Alton's Avatar
May just be the resolution of the pictures, but was the head to cylinder mating surface machined or just bead blasted?
Cheers
www.turn3autosport.com
Old 10-17-2019, 11:12 PM
Chain fence eating turbo
He did mine for much cheaper than that even.....but I didn't need new intake guides, hence the lower price
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 10-18-2019, 07:48 AM
Cheers
I think you're right.
OP, I'd take the heads back and have the surface machined. If I'm not mistaken, that is a tapered cut.
Old 10-18-2019, 07:51 AM
Hbrand
hbrand's Avatar
Cylinderheads
Early cylinders had gaskets to form a seal.
The lip is only to center the cylinders on the heads.
Cheers
1969 Mercedes 280SL
Old 10-18-2019, 08:18 AM
hbrand,
Where new studs were installed are they heli-coiled?
Old 10-18-2019, 08:28 AM
abit off center
cgarr's Avatar
Looks like a time-sert they work great for those areas.
______________________
Craig
G2Performance
Old 10-18-2019, 09:34 AM
Craig.
There’s a vicious rumor going around that you may be contemplating retirement. While I’d be happy for you, if you are could you delay it for a few months. I have a 3.0 I was going to send for machining and afterwards a 2.7. Fun fun!!
Tony
Old 10-18-2019, 10:24 AM
abit off center
cgarr's Avatar
As long as my health holds up which it should I will keep working a long time. I am 60, I kind of promised my daytime employer 8 years plus a lot of my equipment is here. Its actually kind of nice I keep their machines running and I get a nice shop, plus health coverage then I slide in the head work etc.
Craig
G2Performance
Old 10-18-2019, 11:15 AM
Whew. That’s a relief.
Tony
Old 10-18-2019, 04:49 PM
Hbrand
hbrand's Avatar
Cylinderheads
Here is the detail for the work on the 6 heads:
PORSCHE 1966 2-LITER HEADS 0.00 0.00
Labor 250.00 Disassemble, Clean, Bead Blast Heads and Valves
Labor 180.00 R & R and Fit Valve Guides
12 10.00 Parts Valve Guides
12 5.00 Parts Valve Seals
Labor 300.00 High Performance Street Valve Job
Bead Blast Springs, Retainers and Pans,
Set up Valve Spring Shimming and Assemble Heads Labor 300.00
Time-Sert thread repair on six exhaust studs Install new studs 200
Cheers
1969 Mercedes 280SL
Old 10-19-2019, 05:52 AM
cylinder heads before and after
Plus plus plus for Jim and the folks at JB Racing. They did a phenomenal job of machining for a 3.4 I am building.
Pricing is very fair and Jim is extremely knowledgeable and informative.
Old 10-24-2019, 10:19 AM
