Fun supertec 2.8ss build
2.8 liter Hi Performance Street Engine ( 95X66)
95mm 10.0 TO 1 COMPRESSION CP X FORGING PISTONS W/LIGHTWEIGHT PINS MAHLE CYLINDERS 95mm 3.0 911SC ALUMINUM CASE BILLET SUPERTEC SUPER-CRANK 9 BOLT 66 mm stroke , GT3 ROD JOURNALS RECONDITIONED GT3 PANKL TI RODS W/ NEW WR BOLTS DRC BILLET CAM SHAFTS (DC62 102 LC ) SUPERTEC 49MM CAM SEAL BIG PORT 911 SC CYLINDER HEADS 40 MM INTAKE PORTS 38MM EXHAUST WELDED CIS NOTCH SUPERTEC HEAD STUDS AASCO VALVE SPRINGS SUPERTEC TITANIUM VALVE RETAINER MAIN BEARINGS (GT3 RED) ROD BEARINGS (CLEVITE) DRY FILM COATED INTERMEDIATE SHAFT BEARINGS 996 TWIN TURBO OIL PUMP IWIS COMPETITION TIMING CHAINS SUPERTEC TENSIONER ARMS CARRERA CHAIN TENSIONERS SUPERTEC RECONDITION ROCKERS AND SHAFTS ENGINE BALANCE .5 GRAMS VALVE JOB W SILICON / BRONZE GUIDES CUSTOM PLUG WIRES CUSTOM 964 STYLE VALVE COVERS, CUSTOM BUILT MFI PUMP (MFI WERKS) SUPERTEC NYLON 11 FUEL LINES MFI HEAD CONVERSION SUPERTEC COLD START DEVICE SUPERTEC RSR PUMP COVER AND BREATHER HIGH BUTTERFLY INTAKE & SUPERTEC ALUMINUM STACKS W/ ITG FILTERS SUPERTEC GEN III TWIN PLUG DISTRIBUTOR (AARON BURNHAM INPUT) SUPERTEC PLUG WIRE AND CONNECTOR HOLDERS BURNHAM PERFORMANCE SUMP COVER BLAST CASE & REPLACE GALLEY PLUGS STAINLESS STEEL HEADERS DANSK SPORT MUFFLER AMBER FAN SHROUD & PERIMETER TIN (SERIES 900) 228 FAN AND HOUSING RESTORED IN-HOUSE NEW 75 AMP ALTERNATOR CUSTOM IGNITION HARNESS http://forums.pelicanparts.com/uploa...1571759871.JPG http://forums.pelicanparts.com/uploa...1571759871.JPG http://forums.pelicanparts.com/uploa...1571759871.JPG http://forums.pelicanparts.com/uploa...1571759871.JPG http://forums.pelicanparts.com/uploa...1571759871.JPG http://forums.pelicanparts.com/uploa...1571759871.JPG http://forums.pelicanparts.com/uploa...1571759871.JPG http://forums.pelicanparts.com/uploa...1571759871.JPG |
http://forums.pelicanparts.com/uploa...1571760527.jpg
http://forums.pelicanparts.com/uploa...1571760527.JPG http://forums.pelicanparts.com/uploa...1571760527.JPG http://forums.pelicanparts.com/uploa...1571760527.JPG http://forums.pelicanparts.com/uploa...1571760527.JPG http://forums.pelicanparts.com/uploa...1571760527.JPG http://forums.pelicanparts.com/uploa...1571760527.JPG http://forums.pelicanparts.com/uploa...1571760527.JPG http://forums.pelicanparts.com/uploa...1571760527.JPG |
http://forums.pelicanparts.com/uploa...1571761061.jpg
http://forums.pelicanparts.com/uploa...1571761061.JPG http://forums.pelicanparts.com/uploa...1571761061.JPG http://forums.pelicanparts.com/uploa...1571761061.JPG http://forums.pelicanparts.com/uploa...1571761061.JPG http://forums.pelicanparts.com/uploa...1571761061.JPG http://forums.pelicanparts.com/uploa...1571761061.JPG http://forums.pelicanparts.com/uploa...1571761061.JPG http://forums.pelicanparts.com/uploa...1571761061.JPG |
Super serious ($$$) and beautiful ($$$) motor. Congrats. Doesn't Dougherty call the cam the DC65 cam and not the DC62 cam now? That's how it is on his website anyway. I *love* this camshaft. Love the build. That should be a 290-300bhp motor.
A wow motor from Henry
The high butterfly just gives it the look.How about a video when you dyno it for some sound symphony.
Beautiful build Henry! How about some power spec’s
Thanks. |
Very cool. I love the ITG filters on the high butterflies.
ITG filter conversions are our latest product. We take our aluminum stacks and machine them to mate together after installing a filter plate. http://forums.pelicanparts.com/uploa...1571849442.JPG http://forums.pelicanparts.com/uploa...1571849442.JPG http://forums.pelicanparts.com/uploa...1571849442.JPG http://forums.pelicanparts.com/uploa...1571849442.JPG http://forums.pelicanparts.com/uploa...1571849442.JPG |
I need a set of those. We'll talk when I come pick up the throttle bodies. I love the ITG filters on my 2.5
High throttle body injection, 12 plug dizzy, 228 fan, Ti rods, MFI. My dream motor. Yea when I win the lotto, I'll have one like this.
Just another 2.8ss gem from Supertec
Well done Henry on another fine build!
Were the high butterfly TB’s sourced from TwinSpark Racing? |
They were usable as delivered. We put them through our rebuild process, including the flow bench and now they pass our QC. |
Henry, awesome build. Curious where you see the power band for this motor..
Looks really good Henry!
Cheers |
I’d hang it from a big ass gold chain and wear it around my neck with my shirt unbuttoned. Damn that engine is sweet.
Tony |
Man.....just beautiful.
John does great work and I tend to stick with what works/has worked. |
http://forums.pelicanparts.com/uploa...1571930555.jpg |
Awesome Henry!! What is the green material on the cylinder base as the piston is being inserted please?
Thank you.....Henry, sorry I spelled your name wrong....fat fingered ithttp://forums.pelicanparts.com/support/smileys/wat5.gif
That is the cleanest straightest line of Curil T I’ve ever seen. I get it all over the place. Henry is a Curil T artist. Props
Tony |
Thanks Henry |
Gorgeous!
Very nice. Did I miss the fine print (asking price)?
Of course, if I have to ask ............ Sherwood |
Singer (Ed Pink) stratosphere numbers.....no Shade-tree numbers.....no again. |
Henry do you have your cases vapor cleaned? It still appears that some controversy remains ,as to whether its "safe"
Spent the afternoon at Henry's shop and this engine looks even better in person. It's a work of art!
Jee-zus!
Always a tasty build from Supertec! Thx for sharing!! |
thanks for posting! Awesome build, I bet it pulls like a beast!
Not high butterflies, but here's my beautiful set of rebuilt throttle bodies for the 70E sporto I'm putting back together. Henry and his crew do some nice work.
http://forums.pelicanparts.com/uploa...1572616427.jpg |
Stunningly beautiful work Henry! Thanks for your detailed post.
First the RSR replica cover was designed and manufactured by Aaron Burnham exclusively for Supertec. As you can see, it's work of art. It varies from the original RSR cover in that it has a boss to mount our enrichment device. The original thermostat can also be mounted. http://forums.pelicanparts.com/uploa...1572959950.jpg This is a cable operated enrichment device that allows the drive to control the mixture for start up. This is the 3rd generation and we believe the improvements move it to the next level. If you own a 1st or 2nd generation device, we would be happy to up-grade yours for no charge. Simply send it back http://forums.pelicanparts.com/uploa...1572959950.jpg Years ago we decided that hot engine oil in the pump made sense only if you ran a cold start thermostat. So with a enrichment device, sealing the pump was a no brainer. http://forums.pelicanparts.com/uploa...1572959950.jpg As the pump heats up, pressure builds inside so if you seal the pump you have to run a breather. We made this breather a bolt on item the make it user friendly. http://forums.pelicanparts.com/uploa...1572959950.jpg The fuel fitting were originally designed to accommodate the tight space engine compartment on a 917 replica. We were so happy with the results we decided to add it to our list of products. http://forums.pelicanparts.com/uploa...1572959950.jpg Making custom fuels to match the fitting was the logical next step. http://forums.pelicanparts.com/uploa...1572959950.jpg |
fantastic!
Nice looking bits there Henry!
Henry, tell us a bit more about the ITG vs the K&N filters used in your earlier high performance builds please.
Do the ITG’s have superior air flow? Does it just come down to aesthetics? I note the ITG’s come with base plates that allow custom mounting/machining to mag, plastic or individual stacks to match the intakes. This seems to be more flexible than the K&N option which is predrilled for carbs. Regards, Andrew |
First, dyno sheets show an increase in performance with air filters installed vs. no air filter. We did not do a comparative dyno run with K&N. Aesthetics is always a consideration. ITGs offer high quality filtration with a "period correct" feel. Perhaps the largest factor is the universal appeal of the ITG. They allow us to custom fit them to a plethora of custom intakes. We're really happy with the way they fit on our custom high butterfly stacks. With ITG air filters http://forums.pelicanparts.com/uploa...1574001533.png Without air filters http://forums.pelicanparts.com/uploa...1574001533.png http://forums.pelicanparts.com/uploa...1574001128.JPG http://forums.pelicanparts.com/uploa...1574001291.jpg |
| All times are GMT -8. The time now is 10:14 AM. |
