Jeff, in your opinion what would you consider the best HP per $ in an NA aircooled? I have always considered the 3.2SS the best bang for the buck for these cars, I am sure there are a lot of variables that come into play just wondering if you had a general opinion on this one.
I am trying to figure out if I should build a nice lil NA motor or add the evil boost monster to my car. The romantic in me wants the NA, the devil wants the boost lol Thanks |
Geronimo,
I assume you are starting with a 3.0? If so, cost wise, hard to beat going 3.2. If you chose using a 95mm 3.2 cylinder and get it bored and plated. If you chose to buy new cylinders, then may as well go 3.3 with a set of Nickies. If you want more stroke, then a 74.4 crank and rod combo works to get you out to 3.4 or 3.5. Or if buying a crank you can go to a GT3 crank at 76.4 and get 3.8. I haven't really crunched the math to see how much gains one could expect and how much additional dollars it would cost though. But, I am sure someone on here has! Hope that helps
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
No thats awesome, I hope to be ready for a rebuild in 2021, I would love to do the build myself but we'll see where I am between now and then.
I am sure I will be in touch with you. I like very much what I am seeing from you. If I can make 325-345CHP I might just forget all about that boost monster. ![]() Love the work man keep it up! |
What size throttle bodies are you using?
Josh @joshgrowth |
I currently have 46mm PMO's on my internally stock 3.0L My plan if I say NA was to replace the carbs with injection and an aftermarket ECU. Also if I stay NA would like to look at COP and twin plugging it.
Option B, swap the carbs for the 3.2 manifold and add boost
Retired Member
40mm
1982 911 SC Targa - Rosie....my Mistress. Rosewood Metallic on Dark Brown and Black. Long distance road warrior and canyon carver. A few mods - a little interior, some brakes, most suspension and all of the engine. |
