82 SC Head Studs-Replace with????
What is the current view on replacing lower head studs on my 82 SC. One broken, should all be done now? with what -steel, Dilivar, have had many conflicting opinions.
I don't want to rebuild this thing - just fix for now at least cost. Strong running, 50,000 mile motor.
Thanks to all!!
Old 04-02-2003, 10:02 AM
Super Moderator
cstreit's Avatar
NOT dilivar.
993 steel head studs are perfect for a stock or milldly modified SC motor. I use 'em in the racecar.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 04-02-2003, 12:32 PM
steel, do them all. hopefully that head is not pounded by running loose on the cylinder top. they may need a flycut to true the sealing surface.
206 637 4071
Old 04-02-2003, 01:21 PM
Thanks for the input - got any part #'s to go with that info? I reckon I'll replace them all while I'm in there - any tips on removal made easy?
Old 04-02-2003, 04:57 PM
Hilbilly Deluxe
emcon5's Avatar
OK, dumb question: How are the early steel studs different from the 993 steel studs?
Tom
82 911SC Coupe
GTI Cup #43
Old 04-03-2003, 10:37 AM
Senior Member
Doug Zielke's Avatar
Tom......I had a set of both.
The early steel studs were just plain steel.
The 993 studs had some sort of paint/coating on them. (They were steel, not Dilavar; I checked 'em with a magnet.)
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 04-03-2003, 10:38 PM
