82 SC Head Studs-Replace with????
What is the current view on replacing lower head studs on my 82 SC. One broken, should all be done now? with what -steel, Dilivar, have had many conflicting opinions.
I don't want to rebuild this thing - just fix for now at least cost. Strong running, 50,000 mile motor. Thanks to all!! |
Super Moderator
NOT dilivar.
993 steel head studs are perfect for a stock or milldly modified SC motor. I use 'em in the racecar.
steel, do them all. hopefully that head is not pounded by running loose on the cylinder top. they may need a flycut to true the sealing surface.
Thanks for the input - got any part #'s to go with that info? I reckon I'll replace them all while I'm in there - any tips on removal made easy?
Author of "101 Projects"
Agreed with JW. Early steel studs.
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Hilbilly Deluxe
OK, dumb question: How are the early steel studs different from the 993 steel studs?
Tom |
Senior Member
Tom......I had a set of both.
The early steel studs were just plain steel. The 993 studs had some sort of paint/coating on them. (They were steel, not Dilavar; I checked 'em with a magnet.)
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
The 993 ones are threaded along most of their length...
-Wayne
