Broken Head Studs
Looking for recommendations in the Louisville Ky area to remove some broken head studs. Are there any resources locally or will I need to ship the block somewhere?
Thanks |
It is not rocket science, but a lot of shops don't like dealing with wrestling them out, quite tedious and there are 24 of them and the possibility of having to drill and tap and incert. Kind of machine shop work. I am in Atlanta, but I would call shops in your area and ask, is this something you do or not. Bob
Under the radar
They will come out after applying heat from a propane torch to the area where the stud screws into the case. They are glued in and heat melts the glue.
If one is broken off at the case, weld a nut onto the stud and it will come out.
There are four left and they are broken close to the case. I’ve tried welding, but dilivar doesn’t weld well/at all. I tried grinding flat surfaces and using a stud puller, but they are too close. So, before I screw something up, which I am capable of, I would prefer to send this case to someone with experience in getting these out.
The 9 Store
Talk to your local machine shop.
All used parts sold as is. |
How close are they to the case? On my rebuild I had one stud that broke and left me with about an inch. I used some Mapps heat, stud remover tool in pic below (Advance Auto) and attached my impact gun to it. Came right out.
Lou
Under the radar
Electron discharge machining (EDM) is the final go to for broken studs. However, since you can insert the hole, you don't have to be as precise (EDM should leave the threads intact in the case), so you can use cruder methods. It is more of a machine shop which works on car engines than a Porsche repair shop that you are looking for, though your local shops which repair Porsches are apt to have machine shops to do that kind of work, and might tell you who they use.
Post picture.........
Joe, What is the shortest length of the broken dilavar head studs? A picture would be helpful. Thanks. Tony |
When I replaced mine I dubblenutted the unbroken, put some manual tension on them with a spanner and heated the case with a mapp torch.
When it got hot enough you could feel when the "loctite" let go and they would spinn out quite easily. Had to heat 30-45 seconds per stud. If not broken flat with the case you should be able to remove them.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
My experience has been exactly the same as yours. In addition, I found that with the broken ones, I could grind 2 flats on opposing sides, and get a big adjustable wrench on there fairly well. Then use the mapp torch and eventually they would release. I've also had success tig welding nuts onto the dilavar.. I'm a shocking welder. |
![]() ![]() Here are a couple of pics of the two that remain. I tried the tool above and was able to remove three of the last stubborn studs. The two remaining snapped again near the case. I will try again with more heat and maybe a helper to hold the torch. |
It looks to me like you have enough stud there to weld a large nut to them without the sleeve. You said that you tried that? How many amps did you run? You want it hot. The nut ID needs to be large enough to fit over the stud, ideally a tight fit. Slip the nut over the stud about half way and lay the wire in along the od of the stud to get it fused to the nut then fill the rest of the nut up with weld in a circular pattern. Start heating the case with the MAPP torch while you keep torque on the stud. When you feel it break loose start working it back and forth going a little more CCW each time.
Good luck. |
Under the radar
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 01-02-2020 at 10:47 AM.. |
Vice grips, super tight. simplest is almost always the best.
Chris. Got all mine out with a regular stud puller. No heat just elbow grease then installed case savers. Will never pull out again
On my 1984 case i had two studs that were broken off flush with the case, there was not really a way to weld or grab anything. I had a local machine shop (atlanta area) machine them out successfully. No insert needed. If you are in the area let me know and i can give you his contact, very very good shop.
The 9 Store
