TH
Nut in left timing chain housing
Does anyone know if the nut in the left case timing chain housing needs a washer with it? I am about to put the two cases together and Wayne's book doesn't mentioned a washer but just the nut.
The 10 mm nut requires a washer, basically, all nuts require washers.
On 77 and earlier the thread is 10x1.75 like the through bolts On 78 and later the thread is 10x1.0.like the through bolts Bruce Last edited by Flat6pac; 01-04-2020 at 04:44 PM.. |
TH
A wavey lock washer to be exact .
