Help can't install this cis spring loaded.
Ok so how do I load this spring and install it?? Spent the last 2 hours ..I'm stumped.. any help would greatly be appreciated...regards Ned
Old 02-17-2020, 12:46 PM
Air Flow Meter (AFM).......
What model year this AFM unit came from? Was this taken off from a 911 CIS? Looking for something similar to your AFM to check. Thanks.
Tony
Old 02-18-2020, 06:34 AM
After another hour or so I devise the way to install the spring on the bench.. by using a cut 5/16 drill bit . Then placing in the arm and pushing the bit shaft our using the original shaft
Worked really well....shaft
Old 02-18-2020, 08:08 AM
