Sealing Turbo Heads ?
When assembling the 3.3L turbo head (no gasket), it it done dry or do you use the loctite 574 ?
Thanks,
Dave
Old 04-05-2003, 08:21 PM
Irrationally exuberant
ChrisBennet's Avatar
Dry
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 04-06-2003, 06:44 AM
Originally posted by Wayne at Pelican Parts
The head to cam tower interface uses the Loctite 574...
-Wayne
Good point. I assumed you were talking about the cylinder to head interface.
-Chris
Old 04-06-2003, 05:21 PM
Thanks Guys. Yes, I was referring to the head to cylinder interface.
Dave
Old 04-06-2003, 06:57 PM
How does this metal-to-metal, no-gasket head sealing method work out in the long run? I'd think some sort of copper o-ring and groove system would provide a more positive seal. No issues here?
Sherwood Lee
http://members.rennlist.org/911pcars
Old 04-06-2003, 10:34 PM
Navin Johnson
TimT's Avatar
A stock 930 rebuild uses no sealing gasket between the cylinder and head. When building a higher performance 930,sometimes the cylinder and the head is machined to recieve a nirosist ring. Its almost an interference fit between the nirosist ring, the cylinder and the head. This helps keep the cylinder sealed when pushing higher than stock boost.
'69 911 GT-5
'75 914 GT-3
and others
Old 04-07-2003, 01:02 PM
It's interesting that my '77 930 engine (3.0) DOES use a CE-style sealing gasket between cylinder and head. I guess when the factory went to 3.3 they decided it was unnecessary.
Colin
Old 04-07-2003, 04:44 PM
Super Moderator
cstreit's Avatar
Did the same when they moved from 3.0L to 3.2
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 04-07-2003, 09:41 PM
