Hi comp piston question
67 S.
I'm boring it out to 80.5 or 81mm as my bores are worn.
I've been offered the lower comp wossner pistons at a good price.
Is this something to consider or not.
Lyndon
Old 04-10-2020, 09:07 PM
Hi Lyndon,
I have probs opening your PM, I can see "new PM" but can't seen anything in Inbox. Will try to work on that out...
To help Lyndon to get comments, here are details:
Wossner (Wössner) non-S versions so comp ratio app. 9.0:1 , valve pockets looks larger than on std Mahle pistons
Part Number: K9102 (actually K9102D100)
Dim: 80.94mm , clearance 0.06mm
Rings: 810XDS-3 Pin:WP017 Clip: CW22
Br,
Ville
Old 04-10-2020, 11:24 PM
Whether or not they are suitable or the compression will be to low or maybe there is a way I can increase it.
My guess is the few dollars I save will not be worth it ??
Thanks Lyndon
Old 04-10-2020, 11:29 PM
S-version (what Wossner sells) is 10.5 compression if I remember correctly, and some say its bit too high for 2.0 without twin plug.
Old 04-11-2020, 02:08 AM
It's a 914 ...
stownsen914's Avatar
10.5:1 would give some performance increase, but you'd need something better than pump gas for single plug. With 9:1 you'd be safe.
Old 04-11-2020, 07:01 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
you could add a slightly thicker cylinder base gasket to lower compression a bit. The machining of the heads will also add a little compression.
Chris
Old 04-13-2020, 08:44 AM
