Where to recondition 3.2 crankshaft
I bought a used 3.2 crankshaft to eventually replace the one in my '84 with a damaged snout. I want to go ahead and get it reconditioned so it's ready when the time comes, but I'm in no hurry.
Where are the recommended go-to places for this? Is CCR still working out of TX? Marine Crankshafts in CA? Others?
Old 07-14-2020, 01:42 PM
I liked Armando and CCR. Seeing you’re not in a hurry, quality is choice.
Might repair your 84 nose....
Bruce
Old 07-14-2020, 03:31 PM
Can anybody confirm up to date contact info for CCR?
Old 07-16-2020, 07:58 AM
I’ll give it to you on PM
Bruce
Old 07-16-2020, 09:56 AM
Jeff Alton's Avatar
Marine Crankshaft in LA.
www.turn3autosport.com
Old 07-17-2020, 07:33 PM
Bruce
Armando might have a reputation for quality, but he is not a good businessman. We sent him over a dozen cranks to do and we ended up having to have a local customer go collect them from him after he had them for over half a year and many failed promises. He doesn't answer his phone and his voice mail is always full. Just understand this if you do have him do work.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 05-24-2023, 11:42 AM
I just had a great experience with David at Marine Crankshaft Repair. Highly recommend him and his work. Jim
Old 05-24-2023, 10:48 PM
al lkosmal's Avatar
I've used Marine Crankshaft with good results.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 05-26-2023, 09:00 AM
crank
+1 for Marine crank in O.C. in calif.
Old 06-01-2023, 09:31 PM
I used Mile High Crankshaft Repair in Denver after spinning a rod bearing.
Scott Wilburn
1988 911 Carrera 3.4 L
1998 M3
1984 308 QV
Old 06-03-2023, 03:39 PM
I’ve used CCR and Marine and they’re both good. Of the 2, I have slight preference for CCR though.
Old 06-03-2023, 06:57 PM
Jeff Alton's Avatar
Like I said earlier, and others have said. Marine Crankshaft is the place to go. NO drama, Reasonable turn arounds, high quality work. An actual proper business.... Far from a one man band.
Not saying Armando does not do great work, but as a business we can't screw around, and have a situation like Charles at LN had..... Search the forums, not just his one, and see if you want to send your crank there...
Cheers
Old 06-04-2023, 06:14 PM
