Banned
Hope to hear from biggtbiggt to see if the problem went away.
I don't doubt the case could be the cause, but its always to KNOW the real answer without speculation. I worked on things for 30 plus years that you could not see, feel or touch, or even test for directly. They were much more expensive than Porsche stuff |
is it a secret? space ships?
Banned
I don't want to have to shoot you
Author of "101 Projects"
Sounds like satellites or something like that. I wonder what it's like to work on those?
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Banned
![]() The mains pictured here are were removed from a 2.2 with low miles. The reason for the teardown was unrelated to the mains The bearings show little wear note the color on the left isn't copper, but something in the film or whatever. The clearences were all well withing spec as well as taper, roundness, line bore. They were once shiney but have tarnished due to sitting around for a couple of years. I do not think they look a whole lot differen't than the other bearings shown earlier. |
I put the case halves together 2 days ago
Thanks for all the advice! BTW: I knew this engine was not hydraulic locking because it was tight before I even had the pistons
Have a good day eh! |
Banned
Yeh I have had more than some seeping from all the gaskets. I do not in general beleive you should put silicone on gaskets. but with the 911 experience I have had I am going to do it anyway. I am siliconing all the gaskets except the valve covers, which I am using silicone gaskets to start with. A friend of mine who is in the business of doing 911s full time is using 100 percent silicone. Case halves
Jerry Woods specifically recommends using *any* silicone, as he says it will break down when it comes in contact with the oil
-Wayne
Banned
Silicone is ok. The OEMs like Gm arae using it inplace of gaskets. The problems with silicone are:
1. If a chunk breaks off it will plug up almost anything. 2. It supposidly will screw up the bond the gasket is supposed to make with the metal. I agree here but it still SEALS ok as far as I am concerned.. It don't leak. This is counter to what the gasket people like to say. If in doubt don't use the gasket, just use the silicone. |
-Wayne
Irrationally exuberant
Wayne,
First the sugar ![]() I'm an anti-silicone bigot. I don't like the idea of silicone "boogers" plugging my oil squirters. The use of silicone on O-rings seems counter to how I thought an O-ring should work. O-rings are supposed to be able to move around to do their job right? I've never had a motor leak from the through bolts but I've only done a few. That said, smarter more experienced people than myself do use silicone - Dow Corning 730 is a silicone. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Navin Johnson
Chris,
I havent seen Waynes book yet, but I dont imagine he would recommend using silicone sealant for o-rings. Most books recommend using Dow 111 (silicone paste or grease) on the o-rings, I used to use the 111, now I use motor oil. I use a small teeny bead of Dow 730 around the case.
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
![]() Wayne recommends RTV for the case through bolts O-rings. I just put them in a cutoff paper cup with some oil in it before I put them on. -Chris |
'bout time this thread evolved.
Banned
I have to agree with Tim
To each their own, I just recommend what I know works (from all of the experts polled for the book)...
-Wayne
Banned
I bought my own Vitron orings for the case bolts. Seem to work a lot better than the ones supplied by Victor R. I used std 8x2 mm Vitron rings, at about $0.25 ea. Had to buy 500 to get the price.
Banned
Just fired my secretary.
Wow.
'83SC '76 911S - Sold. |
