Twins are more fun!
JMA-RUF's Avatar
Question Turbo: Stroking using a 993 Crankshaft?
I'm considering using a set of 98mm Turbo P&C's (7.5:1) in my 3.2 Carrera Turbo project.
Will the 993 crank drop right in place, or are certain mods required to accommodate this upgrade?
I believe this will get me to ~3.5L, correct?
James
Carrera TT
(3.3, Protomotive MAP ECU, EFI, GT2 EVO CAMs, Twin Plugged, Twin Turbo's)
Old 02-26-2007, 12:56 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Drops right in. You will find that the 993 rods have a narrower wrist pin bushing but that is not an issue. If this is bothersome you can run 3.2/3.3/ 3.6 964 rods in there place.
Just to make Snowman happy, I'd suggest 964 Carrillo rods.
One added bonus is the increase in compression offered by increase stroke.
One more thought, watch your oil pump clearance. The 3.6 pumps have more clearance cast into the housing.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-26-2007, 09:11 PM
Twins are more fun!
JMA-RUF's Avatar
Thank-you for the response, Henry.
If I used, say, 97mm 7.0:1 930/C2T P&C's with a 993 crank, what would the C/R bump up to?
I don't plan to run extreme RPM's on this motor, so I'll stick with the stock 3.2/930 rods and just run some good ARP fasteners.
P.S: Are the 993 piston squirters the same size (2mm) as the 964 squirters? I figure since I have to split the case to do the crank, I might as well upgrade the splash valves too.
James
Carrera TT
Old 02-27-2007, 12:30 AM
930gt-40r's Avatar
I just did the same swap into my 930 case. Im not sure about the squirters, but I do know that I had to screw around with the layshaft gears as the 993 had a diffrent pitch than the 930. If it were me doing it all over again I would have machined the biggest squirters into the block because I have the 993 turbo oil pump. To give you an idea about oil pressure, my motor made 2 BAR (29..PSI) under normal cranking. I just had mine boattailed and dowelpinned.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 02-28-2007, 08:21 AM
WydRyd's Avatar
I run the 964/993 2.0mm piston squirters in my build, as per Todd Knighton's recommendations.
If I ever have to do a full tear-down again, I'll be going down the 993 crank route too with bigger bore P&C's.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 02-28-2007, 07:08 PM
930gt-40r's Avatar
I just want to call it a day and get a 92-94 3.6 n/a motor and build the hell out of it. If someone were to give me 6Gs and a tired 3.6 motor I would trade them my stroked 3.3 with the 3.2 manifold and exhaust.
Kris @ Tech9
86' 930/GT-40R Sold
Old 02-28-2007, 09:55 PM
