Mfi cam seal 49mm. Does it exist?
We are assembling a 3.0l mfi engine (rsr). The cams are 49 mm and the gasket kit contains a 47 mm seal (999 113 068 50 / radial sealing ring).
Does a 35x49x7 mm seal exist?
Thank you
Richard
searching for engine (case) 903742
Old 06-10-2020, 08:31 AM
Yes, google the size, OD, ID and width, and you will find one for a Honda. If you can't come up with it, I have a couple here and will find them and get the size for you.
Old 06-10-2020, 09:26 AM
If you have a chance please do. And thank you for responding
Old 06-10-2020, 09:44 AM
This is a Toyota # 90311-35013. The size is 49x35x7
Old 06-10-2020, 05:50 PM
Thank you very much for sharing this information . Could not find it myself, saves me precious time.
Richard
Old 06-10-2020, 09:20 PM
It's a 914 ...
stownsen914's Avatar
I found another seal in my own searching a couple months ago.
Seal for MFI camshaft drive 49mm for later engines
The Toyota one looks like a good option. Thank you r lane.
Old 06-11-2020, 05:06 AM
