Mfi cam seal 49mm. Does it exist?
We are assembling a 3.0l mfi engine (rsr). The cams are 49 mm and the gasket kit contains a 47 mm seal (999 113 068 50 / radial sealing ring).
Does a 35x49x7 mm seal exist? Thank you Richard
searching for engine (case) 903742 |
Yes, google the size, OD, ID and width, and you will find one for a Honda. If you can't come up with it, I have a couple here and will find them and get the size for you.
If you have a chance please do. And thank you for responding
This is a Toyota # 90311-35013. The size is 49x35x7
Thank you very much for sharing this information . Could not find it myself, saves me precious time.
Richard
It's a 914 ...
I found another seal in my own searching a couple months ago.
Seal for MFI camshaft drive 49mm for later engines The Toyota one looks like a good option. Thank you r lane. |
