Nux Nux is offline
Nux's Avatar
Lighter standard rods - how much is too much?
We are having a generel discussion in our little local community about grinding standard rods.
I know many DIY enthusiasts grind their rods a little to balance them (and I do too), but some seem to take it a step further to grind off some weight as well. I have never grinded more than a few grams off to a perfect balance - but the question is: How much is too much?
Anyone with a scientific approach and actual measurements? Neil?
This particular example is from a 3.0. About 110g has been removed and the owner plan to use these for a mild 3.0 engine build with 9.8:1 CR. Max rpm will be 7500. Cross-drilled crank and standard oilpump.
"why not just buy Carillo or Pauter".
I'm interested in the science and knowledge behind this. Are there ways to improve these engines, without just buying new stuff. What can be done - and perhaps more importantly : What can not be done.
Old 10-07-2019, 11:51 PM
It's a 914 ...
stownsen914's Avatar
Some 911 rods had surface treatments that of course would be removed by doing something like this. Might have been only the early S rods (nitriding), but not sure what other may have had. I admire the ingenuity but wonder if an an errant nick could become a stress riser.
Old 10-08-2019, 05:28 AM
How much does a stock 3.0 rod weigh? 670 gms, give or take? Pauter shows a 511 gm 3.0 rod, off the shelf.
When I had to run stock type rods in class racing, we'd polish the beams, then send them out for shotpeening, then replace the bolts and resize them. The cost ended up being about the same as a set of aftermarket H-beam rods. And the H-beam rods were a lot lighter.
Old 10-08-2019, 05:55 AM
less weight
I would never grind the big end but only lighten up around the small end bushing.Fred
Old 10-08-2019, 06:05 AM
The crank is NOT cross drilled! ... It is 11.3: 1 CR
But yes, max revolutions at 7200 ish ... I should know, cause it's mine!
In this case, it must NOT be shotpeened! the trick is that the surface should be as smooth and shiny as possible! (this is actually old knowledge) This "confuses" the crack formation, and distributes the load over a larger surface and thus makes it stronger. According to engineer calculations (can't find that claim right now) with up to 20%!
In addition, this must be offset by the weight removed, accelerated to a given rotational speed. The connecting rod in the picture is an org. SC forged connecting rod, that has its strength due to the direction of the structure of the metal itself, not due to a surface treatment.
They are lightened 110g, up to 10g less when finished polished. In addition, it gets new pistons that are lighter than the original, let's just say 30g. It will be 150g less per connecting rod it has to "resist".
This also goes in the right direction in terms of help on "lost" strength
This applies to an NA engine. But even in a turbo engine, you usually see that it is the arm that is bent due to too much load, and I have not removed anything from this place, only polished it.
What does it cost? sweat and evenings ....
Why do it? Cause I can!
Old 11-17-2020, 11:46 AM
targa72e's Avatar
If you really want to lose weight Pankl titanium GT3 rods are 425g with bolts and are the same big end dimensions and length as 3.0 rods (also avalible in 130mm length)
john
Old 11-17-2020, 12:27 PM
Is there a reduced lifecycle for Pankl titanium GT3 rods, compared to factory rods?
Rahl
1976 930 turbo Carrera, "Ubich". Mostly stock, lightly sweetened. She’s an angry schwierigkeit. She doesn’t want flowers, she just wants to dance! And when she does, she shakes her hips to the rythem of the road. Drive her like you hate her!
Old 11-17-2020, 12:53 PM
john
Yep... But they cost money ...
Old 11-17-2020, 02:20 PM
Originally Posted by Aircooled4evr View Post
... In this case, it must NOT be shotpeened! ..."
I am not trying to start an argument, just trying to clear up what seems to be a misconception about shot peening...
"Shot peening is a cold working process used to produce a compressive residual stress layer and modify the mechanical properties of metals and composites. It entails striking a surface with shot (round metallic, glass, or ceramic particles) with force sufficient to create plastic deformation.[1][2]
In machining, shot peening is used to strengthen and relieve stress in components like steel automobile crankshafts and connecting rods. In architecture it provides a muted finish to metal."
https://en.wikipedia.org/wiki/Shot_peening#:~:text=Shot%20peening%20is%20a%20col d,sufficient%20to%20create%20plastic%20deformation.
It is your motor - do what makes you happy.
Old 11-17-2020, 02:21 PM
I would really like to see documentation of the 20% increase in fatigue life. I admire the amount of effort you have expended. I don't believe polished is better that shot peen. The industry and engineering data I know of support a robust compressive stress to increase fatigue life. Curtiss-Wright Surface Technology uses a massive Laser to create a steam hammer effect to "shock peen" critical metal parts to improve fatigue life. To do better, for this contest, you need to bring a big hammer 😃
Old 11-18-2020, 04:38 AM
I worked on life extension programs for Sikorsky helicopters and submitted technical reports to the FAA for approval of Time-Life Limited parts on helicopters. One of our main processes for for extending part life and getting acceptance thru the FAA was our shot peening process. I do not think the polishing method will help strengthen anything (except reduce the smallest amount of air resistance). If you think about the surface on a microscopic level you really have not changed or reduced any imperfections or possible crack initiation areas by polishing.
Rahl
Old 11-18-2020, 08:48 AM
Engineering and science prevail... yet again. GO figure... ;-)
Old 11-18-2020, 09:25 AM
Cracks (dislocations) are failures resultant of tensile stress.
Polishing will improve fatigue life by reducing the probability of a surface defect where the critical crack length will result in formation of a dislocation.
Shot peening creates a compressive surface layer that must be exceeded in addition to the minimum stress for a given defect critical crack length. Additionally the plastic deformation of the surface probably improves things further. Similarly nitriding also creates a compressive surface layer through a diffusion process.
Nevertheless solutions cannot be applied without thought to the failure mode, at best these are best practises without specifying a desired fatigue life and applied stress.
Old 11-18-2020, 02:41 PM
David's Avatar
Doesn’t seem like the reward to risk ratio is high enough to warrant lightening stock rods. The Pauter rods are so much lighter and actually decrease risk of failure that it seems a much better option.
Old 11-26-2020, 03:26 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Removing material from the rod cap ridge on a 911 rod is never a good idea. The "ridge" is structural and designed to provide rigidity. Some people grind this boss (ridge) to balance the rod but even this small amount compromises the rigidity and may allow excessive cap flex at higher rpm.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 11-27-2020, 02:08 PM
Walt Fricke's Avatar
Henry's caution is also what came to my mind. A shop I used send my stock rods off for balancing. These guys were used to Chevy type rods, where the big boss on the bottom was there specifically for balancing. They cut down the ridge quite a lot. Very embarrassing for the shop, which found another set of good used stock rods for me and had them balanced. Typically very little is removed in order to get a set balanced. There are several spots which apparently don't affect strength, but this ridge isn't one of them, and you don't have to be an engineer to appreciate its function.
I am dubious that very much weight can be removed without altering where the highest stress levels are, or without increasing those stresses. There are programs and techniques for determining what and where these stresses are. FEA? I've got a saved picture of a rod showing just that, but it certainly is not really adequate for home brew weight redistribution.
This appears to be a Carillo type H beam rod. I wonder if the analysis was done only for compression? The bottom of the rod is what takes up tension on that end as the piston hits TDC on the exhaust stroke.
Here is a similar view of stresses on a rod bolt.
Not sure just why the stesses are so concentrated in the threaded end, though the press fit nature of the rest of the bolt may spread the tensile forces out more than at the nut end? The bolt I had fail on me broke about in the yellow area - you could see how both pieces were necked down there on each side of the break.
Old 11-27-2020, 05:12 PM
targa72e's Avatar
When Porsche finally did FEA with the redesign in the 993 the rod changed significantly. Most of the reduction was in the beam. These same rods (and crankshaft) were used in the 996/997 turbos as well. Picture of 993 rod.
The 964 rod which was also used in the 3.2 Carreras and originated in the 3.3 turbo from 78. It looks much like a SC rod. Picture of 964 rod.
My guess is that you might get away with a rod with material removed like in the original post (or not) because the rod is way over engineered for a 180HP motor with a 6300 redline.
John
Old 11-28-2020, 12:37 PM
John
If the goal is 180hp and 6300 reline why bother lightening them at all?
Henry Schmidt
Ph: 760-728-3062
Old 11-28-2020, 04:52 PM
My goal is 250 + hp and red line at 7000 - 7200
but ... if I go for 100mm cyl and pistons (= 3.3) I probably can't keep it near 250, with the ideas I have for the engine in general. And my wepcam 20/21 will probably be too small too.... and my SSI exhaust
Old 11-29-2020, 06:46 AM
well, I also have these in reserve ... But they are not as light as "mine" and I do not want to use mine with anything other than lighter pistons than the original.
I still think they are seriously over-engineered. Speaking of which, weren't the original connecting rods also the ones they used in the turbo variant of the 3l block ?!
the engine was designed to run with up to 800hp in their race cars.? Was that with other connecting rods? I can't find any info on this...
Old 11-29-2020, 11:11 AM
