Making the 2.7 mag work is a lot of work, and it'll never be as strong as a 3.0. The reason I did mine was, that I already had the engine. |
I'll get on to that asap - which is in 5 months, winter has arrived here ![]() I was thinking of something like: 1300-1500-1800-2100-2500, where I remove 4500. 3900-5100 are fairly similar. How how does that sound? Last edited by CarreraEvo; 11-01-2020 at 01:09 AM.. Reason: Elaboration |
Racer
So you are saying you are getting 271 HP at the wheels from this 2.7 build?
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Not at the wheels - as I understand it the dyno meassures the transmission loss when it coasts down after the run. Once it’s down to about starting speed, it subtracts the losses and you get engine hp.
Racer
271 HP at the crank is a little optimistic for that build especially at 7000 RPM. What correction factor did the dyno software apply?
Other than that, I don't know. But I tend to agree, 271HP is a lot - I was pleasently surprised ![]() But in the end, it's just a number. |
thanks
Ill look for a 3.0 or 3.2 many thanks
Congrats on your rebuild, very clean and incredible outcome. I have single TB 3.2 MS1 EFI setup on my rebuilt 3.0 but I want to go ITB and those ITBs seem to be the ticket for max flow. Can you describe the fabricating to make the filters fit the trumpets? Did you seal the plate to trumpet interface or use some sort of gasket? It looks really clean overall. -cheers
The filters from Pipercross came with a bottom plate with no holes. So I made 3 holes about 8mm larger in diameter than the trumpets. Then I used sliced silicone tubes as gaskets. I installed 4 studs from each of the ITBs to keep the plate in place. I’ll look for a photo. |
Pic of filter plate
Nice work. Thanks for sharing.
Henry |
Great build! I was wondering how you got the Bosch PWM idle air valve hooked up. The wires, I suppose, go to the MS as described in the manual. But how did you hook up the air hoses?
Diederick I drive a US import 1977 911. Formerly owned by a woman in California named Ginger - which appropriately led to the nickname. IG: no dedicated account but photos are posted with #ginger77 |
I don't think the answer is in the PC unless you're looking for photos. I literally mean how did you hook up the mechanical side of the valve? Not the electrical wires.
![]() The idle valve blows air but into where? I get the principal with a regular injection intake boot. But I don't see how it works with us using filter or stacks.
Basically I run a hose from each TB to a plenum, a single hose from the plenum to the idle valve and a single hose from idle valve to the right side air box. Below are the two best photos I could find. It looks as if the hose from idle valve to air box is not fitted in the below photos. If it doesn't make sense, I can snap some better photos for you? |
Outstanding build! Peak HP @7k plus should net 100hp/liter. Looks like yours is healthy. If you can figure fuel lbs/hr for your build, you can verify the Dyno results. Also, if you can get the injector quantity per cycle, that would work as well.
Wiring Harness
Where did you source you wiring harness
Nice result, very impressive results.
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
