Originally Posted by Henry Schmidt View Post
Slotting the cylinders to adjust head stud spacing, reducing the spigot diameter (thinner cylinder wall), boring the case (irreversible change), .120" base shim.(unstable cylinder platform). If you try to use late 964/993 cylinders you have to machine the heads flat. More irreversible changes.
All of it is ugly.
Back in the day when the 964 recall happened, the dealers had boxes of the early cylinders they were throwing away. One batch we got was 11 sets. That makes playing with these cylinders intriguing.
Now, not so much.
I have to come up with a plan for the two 3.0s I have. I could see where all these changes would invite issues down the road.
Old 12-04-2020, 05:37 AM
Try not, Do or Do not
Henry Schmidt's Avatar
There is always this option....
Porsche 911SC-Leistungsgesteigert (Performance increased)
We're starting a simple 911 SC rebuild and resurrecting a little know option offered by Porsche by in 78-81.
Here's some information.
We're making sets using 95mm cylinders bored to 97mm and plated by Millennium. CP X-brace pistons are then custom fitted.
The pistons are designed to use 3.3 liter turbo rings so replacement is cheap and easy.
$ 3,185.00 plus shipping.
Engine type 930.03 or 930.09 * 3.1 *
Engine displacement: 3122 cc
Bore x Stroke: 97mm x 70.4mm
Power: 210 hp @ 5900 rpm Binary: 280 Nm @ 4300 rpm
0 at 100 km / h: 6.4 seconds Max speed: 230 km / h
The Forgotten 911SC-L
Porsche's 1st factory tuning engine kit that was NOT in the option list for those years (Dealer Secret)
Rolf Sprenger, The Father of the Porsche MFI for the road cars and the Slant Nose 930
Designed this 3.1, 210hp Tuning kit for customers that were not happy with the output and performance of the normal 911SC 3.0 78-81
This tuning kit has a output of 210HP @5800 RPM and 206 Torque @ 4700rpm
Roth used 97mm 3.3 Turbo Cylinders with 9.5:1 compression Pistons made it 3122CC
3.1-L Engine Leistungsgesteigert or Increased Power
Bosch reworked the CIS injection with new Distributor
Taller 5th gear and larger oil cooler from the race department
3750.00 dollar Option in 1978
ONLY spread word of mouth at Porsche Dealers showroom
when customers voiced displeasure of the performance of a normal 911SC
Never was available in the USA only Europe and ROW and only a Letter from Rolf was included in the glove box with this upgrade
No way of knowing how many of these tuning kits were made
Some estimate 200-300 unit made
Roth Sprenger Personal notes and Porsche refusal to Market the SC-L
almost left no documentation to this special rare 911
We will include a reground set of Carrera cams. The new profile is 964.
When purchased at the same time as the piston and cylinder set, the price is $500.00 exchange. You can exchange 911SC or Carrera cams for the core.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 12-04-2020, 06:11 AM
[QUOTE=[B]Henry Schmidt[/B];11126405]We can have the custom pistons made for you at a reasonable price.
Send me an email with contact info and we'll try to work something out.
Discount for quantity? of course, we've got piles of the stuff.
Wow! I obviously don't know who I am "talking" with in here!
Sorry for my late reply. But now I'm finally back in my beloved "porsche world" I think it will be easier if I just send you an email!
Cheers, Mads
Old 12-10-2020, 05:59 AM
Porsche Crest
You can modify them if you have a mill and a lathe.
I would seek a custom piston to maximize this modification.
70.4x100 is a cool high revving oversquare engine. They are commonly found in the likes of Formula 1 cars, two-stroke racing engines and anything else where you want to rev the engine up to produce power. They keep piston speed down which helps reliability by putting less force into things like your crankshaft and connecting rods. In general, these engines will produce more horsepower than torque and require gearing to take advantage of their top end pull.
We built a 66x100 engine a few years back that saw rpm close to 9000.
Henry, a little off topic but can you describe the characteristics and/or your experience with a 3.2 modified with a 80.4 mm stroke and 100mm bore. I'm also wondering if retaining the motronic efi would be adequate in a street car with say a 7,000 RPM limit. Thank you for your contributions to this forum.
Old 12-11-2020, 12:09 PM
Henry I’m still debating what to do, I’m thinking maybe I should sell both of my 3.0 and get something else, but people are asking stupid money for 3.2’s et. Maybe I should give you a call I don’t know any east coast places.
Old 12-12-2020, 10:38 AM
80.4 stroke in an air-cooled engine will need pretty short rods or some crazy dimensioning. Long stroke generally means better torque but nasty rod angles.
The stock 3.2 injection will support very large engine with the right injectors and programing.
Henry Schmidt
Ph: 760-728-3062
Old 12-12-2020, 11:17 AM
A 3.0 core is a great platform if size is not your primary concern.
You can email me with question/thoughts and we'll tease something out or
you can call as well but right now my scheduling is unpredictable.
Henry Schmidt
Ph: 760-728-3062
Old 12-12-2020, 11:22 AM
I haven't looked in years but I may even have a set of slotted cylinders and base shims on the shelf ready to go.
If I can remember, I'll check tomorrow.
Send me an email.
Hi Henry Schmidt, I'm interested in buying a good 100mm set of you, and maybe a set of pistons as well. But I have several questions.
My email is: madsracing@gmail.com
(yeah yeah ... You may laugh now ... I was young when I made it!) ...
However, I will also try to write to you.
Sincerely, mads
Old 12-27-2020, 08:35 AM
Hi folks. Do you know, if this is an active mail for Henry Schmidt: supertec1@earthlink.net ?
Old 12-30-2020, 06:24 PM
Christmas vacation. We'll talk after the new year.
Cheers
Henry Schmidt
Ph: 760-728-3062
Old 12-30-2020, 08:11 PM
Yay ... Wish you, and everyone in here, a happy new year, MUCH better than 2020!
Old 12-31-2020, 04:57 AM
Will there be a problem with driving with the original 964 pistons, with new piston rings? I'm thinking, my plan is to drive with high compression, dual ignition, knock sensor and everything else that the 964 has. So is this not a sensible way to go?
Old 01-12-2021, 12:08 PM
Originally Posted by Aircooled4evr View Post
Primarily because of the price!....
I can make the modifications myself, to use the 100mm.
And if the heads need to be modified, to achieve a better squeeze in collaboration with the 964 pistons, I can probably do this as well. (even though I just finished polishing them)
In addition, I'm curious what characteristics 70.4 X 100mm will give!
Mine hauls ass.
If you don't need to cut the case, don't.
Mine came to me this way I wish it was not. It makes it a real headache if i ever have the cyls that came in it damaged and need to replace them.
While its good to know I can potentially do something with 964 cyls it looks like something id rather avoid.
My case was opened up to take some Mahle Motorsport cyls and pistons that are 100mm
1976 914
1986 951
Old 01-12-2021, 05:12 PM
Originally Posted by colingreene View Post
Mine hauls ass.
I really had problems reading after this ...
Old 01-13-2021, 08:52 AM
Mine hauls ass.
OK, I'm still on my way to the 964s 100mm... But ... anyone have a qualified bid where one could find a set of Mahle 98mm cyl for human money? (and what is "human money" for you guys)?
Old 01-13-2021, 09:00 AM
well whatever?
I just dont think its a good idea.
1976 914
1986 951
Old 01-13-2021, 12:02 PM
well whatever?
100% meant for fun!
Old 01-13-2021, 02:14 PM
Still looking for cylinders? Send me an email and I'll give you the latest information from my parts store.
Cheers
Henry Schmidt
Ph: 760-728-3062
Old 01-14-2021, 05:07 AM
Cheers
You've got Mail.
Old 01-14-2021, 06:30 AM
