The air path for absorbed and rejected heat from these coolers is directed into the air cooling stream instead of dumping heated air outside the vehicle. This raises the temperature of the ambient temperature air flow, not ideal. Sherwood |
Henry, understood and acknowledged. It’s also a major project to install a front cooler with its plumbing in the tight space constraints.
http://forums.pelicanparts.com/uploa...1611797550.png |
mepstein hits the bullseye as expected. If you are going to add an oil cooler to a 914, do it the way the factory did. This is the way I did mine along with the PMS oil cooler and thermostat. The car never overheats and I am running a 3.2 in the CA Bay Area where we see 105 degrees in the summer with lots of traffic.
Henry,
So the Rx 7 cooler has a built in TStat? Any reason this would not work plumbed in to the scavenge side of the original oil system? Seems that would be a most simple system. Scavenge outlet plumbed into this cooler with built in thermostat controlling flow to the cooler. Agreed that this cooler location is not optimal, but my gut instinct engineering feel is that increases in charge temp would be small and oil cooling effective. |
By using a sandwich plate as I described, the entire project is a bolt on accessory. Modifying the deck lid is the only permanent alteration. That's why sourcing another deck lid makes sense. Paint it to match, save the original and you win. The 914-6 is climbing in value.....mess with it at the cost of originality and resale value. |
For a full flow cooler, the inlet and outlet ports are typically replaced by larger weld-on adapters (e.g. AN-12, -16).
The MB unit you can use as is, a lot less work. |
http://forums.pelicanparts.com/uploa...1743468989.jpg http://forums.pelicanparts.com/uploa...1743468989.jpg http://forums.pelicanparts.com/uploa...1743468989.jpg http://forums.pelicanparts.com/uploa...1743468989.jpg http://forums.pelicanparts.com/uploa...1743468989.jpg http://forums.pelicanparts.com/uploa...1743468989.jpg |
Nice to see my old 6 looking so good! Didn't know you had Harvey make you a set of 8R's for the rears. Nice touch. Thanks for posting Freeman.
Wow, amazing look and solution.
Wow! I haven't seen that car in over 20 years. Glad to see it's still running well.
I used that style lid cooler on my own 914/6 with multiple engines for decades. No cooling issues even on 100+ days blasting out to Vegas. http://forums.pelicanparts.com/uploa...1743610267.jpg http://forums.pelicanparts.com/uploa...1743610267.JPG |
Here’s the original ad for the motor which was included in the paperwork file. |
As I understand Henry's conversion, there is zero modification to the original body and chassis. Zero modification if you source a different engine lid like stevesc_us apparently did. |
I have a set of NOS factory GT flairs and I have a pair of stock factory rear fenders. So far I like the look as it is and it allows the 8R rear Fuchs. On the cooler install, they were installed without any cutting or holes added. We used existing bolts and studs by creating custom brackets. http://forums.pelicanparts.com/uploa...1743863994.jpg http://forums.pelicanparts.com/uploa...1743863994.jpg http://forums.pelicanparts.com/uploa...1743863994.jpg http://forums.pelicanparts.com/uploa...1743863994.jpg http://forums.pelicanparts.com/uploa...1743863994.jpg http://forums.pelicanparts.com/uploa...1743863994.jpg http://forums.pelicanparts.com/uploa...1743863994.jpg http://forums.pelicanparts.com/uploa...1743863994.jpg |
I like the flairs and your car is beautiful. I saw it in Costa Mesa when the cooler was being installed. I did a similar flair on one of my 6s back in the late 70s so yes, flairs have been added to 914s for decades. I even like the add on passenger mirror.
It's your car and you can do whatever you want. It's just weird that you find a need to justify your decisions. |
| All times are GMT -8. The time now is 05:02 AM. |
