"O Gruppe 13"
IDGAF27's Avatar
Send a message via Skype™ to IDGAF27
Educate me, Please
What are the history and reasoning for these been used on race engines back in a day?
Thanks in advance
G-Man
89 964 C4
86 930
Old 01-13-2021, 10:32 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Standard equipment timing sprocket for the earliest 911 engines.
Generally not used in race engines. Too much unnecessary weight.
I guess someone may have felt they offered a more secure method of holding the timing pin?
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-13-2021, 01:47 PM
"O Gruppe 13"
IDGAF27's Avatar
"Someone" being factory? I was told they came Only on racing engines.
This pair came off of 935 engine.
G-Man
89 964 C4
86 930
Old 01-13-2021, 07:30 PM
I have the same in my 67S, I guess you can shave a few grams by using the later ones.
andy
Old 01-13-2021, 10:24 PM
The ether is full of legends about Porsche parts and what can on what engine and in what car.
The "truth" is: I have 25+ sets in a box in my shop.
Zero came from a factory race engine.
If this legend was true, I have a plethora of valuable race parts that need to be marketed to the gullible.
Henry Schmidt
Ph: 760-728-3062
Old 01-14-2021, 04:44 AM
andy
Weight was only one possibility for redesigning the hub. The chain drive mechanism is already overweight adding to the parasitic losses.. That is why the factory fitted aluminum parts wherever they could. The later open hub may also be an attempt to minimize damage in the case of cam seizure/stoppage. The full circle hub will not break under heavy loading (catastrophic failure) and the teeth on the later version will shear off mitigating collateral damage.
Henry Schmidt
Ph: 760-728-3062
Old 01-14-2021, 05:04 AM
targa72e's Avatar
Yep, I have some of those. out of a early engine (think it was 68-or 69 engine).
John
Old 01-14-2021, 12:01 PM
"O Gruppe 13"
IDGAF27's Avatar
Yay...so your credentials for speculation are better ranked than mine. congratulations!
..and all I asked for was the FACTS not an opinions.
G-Man
89 964 C4
86 930
Old 01-14-2021, 07:33 PM
It's a conversation...trying to limit the responses you get seems a little counter productive.
Henry Schmidt
Ph: 760-728-3062
Old 01-15-2021, 06:44 AM
I'd listen to Henry. If he tells you what it is, he's giving you advice on decades of experience. I'm sure he's pulled apart exponentially more engines than I, and I've pulled apart a lot.
Old 01-15-2021, 08:20 AM
No one has to listen to my noise....I'm just rattling on about the cars I love.
Believe me, investigate what I say, ignore me completely or challenge what I offer.
It makes no difference to me but I will keep offering the noise.
Henry Schmidt
Ph: 760-728-3062
Old 01-15-2021, 09:55 AM
Harpo's Avatar
We appreciate all the "noise" you care to share with us
Old 01-21-2021, 01:40 PM
