Port my 3.0L or buy 3.2L
I have an 83 (3.0L) in my 74. Should I have my existing heads ported or should I buy a set of 3.2L Heads. My long term plans are for a 3.2ss
Thanks David Last edited by Harpo; 01-30-2021 at 06:13 PM.. |
Try not, Do or Do not
Depending on your proposed course of action (IE: design of your 3.2SS) the small port SC cylinder heads offer the greater number of options. Valves are the same size and angle so no advantage either way.
The main difference is the intake flange. The SC flange is taller. This allows you to get more creative with your porting. Basically, the 3.2 head is already over-ported. The taller SC flange also allows for space to machine an injector port if you choose to go old school with MFI. The only real benefit to Carrera heads is the head temp mounting point. If you end up needing that feature a good machine shop can add it.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
