Pin placement question
I am a bit puzzled about the pin placement. Ive read somewhere that pin placement is an issue when going from 2.2 to 2.4? Is it related to the different lenght of rods/crank of the 2.2 vs 2.4? Are the pistons physically the same
apart from comp ratio? Id assume so, as Wayne suggests in his book to put 2.2S pistons into a 2.4S case, making it way better than 2.4S. Am i finally getting something right???? - A complete novice still puzzled by that simple 911 rebuild operation.....
PCA Member 2009 Audi A3 2.0 Quattro 1978 911 SC Targa |
Author of "101 Projects"
The rods are different between the two engines, and as a result, the wrist pin holes in the pistons changed. This is because the deck height needs to be the same for the pistons. I can't recall which pistons are closer to the edge, and I don't have a set available here to check...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
