Formerly reformed
Would Someone Please ID This?
Found in strainer of '72 2,4 engine. Measures ~20mm outer ~12mm inner. The missing piece is accounted for.
1968 911P (Paperweight)
Old 03-02-2021, 10:02 AM
Formerly reformed
Really? Nobody? So I have phantom parts floating around inside the case. Considering the source, it's not too surprising.
Old 03-02-2021, 04:15 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Distributor washer. Goes between the gear and housing.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-02-2021, 04:47 PM
Formerly reformed
Thank you, Henry. I needed that.
Old 03-02-2021, 05:33 PM
