Try not, Do or Do not
Valiant effort but not much heart.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
I have plenty of heart, but I am allergic to drama. I personally had rather encourage or help people not tear them down. This is not directed at any one person, I am just trying to explain why I do not wish to engage in these threads where it seems like a drama show to me.
Alas, poor Yorick.... I knew him, Horatio: a fellow of infinite jest, of most excellent fancy: he hath borne me on his back a thousand times........ I forget the rest but you get the idea. This is drama. What we see most often in these threads is hubris mixed with hurt feeling and egos run a muck. To help, you offer actual data backed by experience sans confirmation bias and personalities.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 02-26-2021 at 08:30 AM.. |
Easily Confused
Head studs and firearms in the same thread? Wow, this one really delivers! It sure warms this Texan's heart. ![]() My inputs are not to add fuel to any argument but to share my findings for others to consider. People in the 1-2 Sigma category of use-cases. Like any good engineer, the answer to any problem usually starts with "It depends...." I find there are few absolutes in life so I look at the application and situation. I took the approach William notes above. I wanted to be practical as I have a stock 3.2 that sees a few thousand miles a year. Additionally, I consulted with a trusted Porsche tech (40 years of dealership experience) and his counsel was to go back with steel studs on a stock engine. He's seen Dilivar broken on new car deliveries and seen them go 200k miles. I understand his viewpoint is to build an engine and make sure it doesn't come back for a warranty claim and I just want a reliable mill. Just like when people ask me what firearm they should buy.... I ask about the intended use. Bigger and badder is not always better given the use-case. One wouldn't use a 50BMG for a house gun nor a .22 short for Antelope hunting at 400 yards. As always, "It depends...."
Scott C. '08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65 |
Scott,
Scott C, I appreciate the support.. There is not one good solution for everything. Everything has some problem 993 TT is price and no one cares for the all thread. Supertech studs almost are never available when I call. I do not have enough experience with them on high hp builds mostly because he is always out of them. Now to more interesting fun stuff while you brought it up.. I have a TRG 42 in 338 Lapua. I shoot it better at 1500 meters than anything I have ever owned including the AI I sold. But the 338 Lapua wouldn't be good for deer but will outrange a 50 BMG all day. I am a 45/70 fan and I prefer single shots. I have S&B, US Optics, Lecia scopes but I find Valdada to be the most clear. Hopefully this was a nice shift in the thread. |
SAKO makes excellent rifles.
87 Carrera Venetian Blue gone but not forgotten. |
Easily Confused
338 does a nice job on 300# hogs here. I've tipped a few over at 200 yds with 338. One shot and no movement.
My preferred tack driver is GA Precision .308 with a Leupold VX-3 8.5-25 50mm objective. I can consistently hit a pumpkin at 700 yds and a human silhouette at 1k yards with some serious drop compensation. When I win the lottery, it will be the 408 CheyTac from Cheyenne Tactical. I've wanted one for years. For a truck gun, the 300 blackout in an 8" SBR (with Tax stamp). Ballistically equivalent to 45ACP with 30 rounds. Good for hogs and varmints of all types. Now I feel the urge to send some lead downrange! Alas, I need to pay for my 3.2 rebuild. Too many expensive hobbies. UGH!
Scott, did you know the 408 round is the only round that stays stable when it falls subsonic ? True and it makes it the best round but it was actually an accidental discovery on the stability. Rounds too hard to get for my taste. My TRG42 has a 5-25 34 mm US Optics.
Can we get back to anecdotal opinions? :-)
I decided to use (actually reuse) the 993TT Dilavar studs because they would cost too much to replace in kind (~$40-$60x24) or switch to the alternate studs discussed here. It came with the engine I touched up a bit. How's that for being "helpful"? ![]() Sherwood By the way, why aren't all bullets shaped to a sharp point? Is that enough minutia to take this off-topic again? |
I can answer the bullet question it gives a lower BC. But I have reused 993TT studs several times no issues.
Just for fun, if you haven't already rebuilt the heads, can you post a few pictures of the sealing surface?
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 02-27-2021 at 07:27 AM.. |
It’s actually a 3.2. I may have to risk that possibility. I’ll keep my fingers crossed though. |
Any chance of head pictures?
Not many and none of the combustion chambers. Heads were rebuilt (guides, etc.), nothing special. Went as far as rebuilding the rods (w/ARP fasteners) and replacing rod bearings. Sherwood |
When you rebuilt the heads did you machine the sealing surface?
Yes. Took a little off +.
Why? To clean up the sealing surface and to incrementally increase the compression ratio. I recall 0.025". Oh, and a set of 964 cams in the aforementioned 3.2.
Years ago, I did the same with my modified 2.0>2.7 w/S heads with E cams and RS pistons and their optimistic 8:1 CR. It worked fine if not noticeable Shouldn't have? If I asked if I should have done more, might I have expected a resounding yes? |
Although I never replace rod bearings without splitting the case, it sounds like you're doing a great job.
When I disassembled the top end, I didn't notice any appreciable erosion of the cylinder head sealing surfaces. It was a running engine with typically worn valve guides. No other apparent issues.
Keep up the good work. Sherwood |
