Thoughts on twin pluging Euro spec 3.2
I am rebuilding my 89 3.2 using new Euro Mahle pistons and cylinders that are advertised at 10.3:1.
I understand that the actual compression may be lower than the advertised compression but was wondering the logic on whether I should twin plug the engine due to the increased compression over the North American spec engine. I will be changing the cam profile as well to 993SS or similar during the rebuild as well but retaining the motronic injection. We have 91 and 93 octane fuel available but I wouldn't want to limit myself to having to run 93 only, as it isn't as widely available. Thanks, Todd
1989 911 Targa |
Puny Bird
I can do the head and cover mods, no broken fins.
PM if interested. That said I think you can get away with (9.3-9.5CR) and single plug.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
Try not, Do or Do not
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Yes, measure. The Euro pistons we have measured were never over 10:1 despite what the book says. Base gasket will get you down to where you can still run single plug easily. That all said, we have quite a few Euro spec cars we service, all original single plug. No detonation with good fuel.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
I speculate that Mahle advertises the compression ratio @ 1mm deck and does not account for the CC between the crown and the top Ring. So it's gross Dome volume. Once you account for the .6cc loss and a standard 1.25mm deck the Compression is about 9.92 provided everything is in spec. YRMV
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
Thanks all for the comments. I will certainly measure the compression as suggested. The additional cost to twin plug it really isn't that great so it might make sense to just have the machining done while it is apart.
-Todd
1989 911 Targa |
Puny Bird
The machining is only part of the cost, then you need the kit to fire 12 plugs. This can be done DYI for under $1k but most systems are $3k to over $10k. One avenue I'd explore is if MS can be run ignition only, then you have the future option of going full EFI.
One thing you could do is the maths for both single and twin plug, set it up for single plug and once you decide to take the TP plunge you can loosen the jugs, clip a shim and you're good to go for twin plug.
Thanks. I'm well aware of what is required to run twin plug and on the motronic it really only needs a 964 distributor, a bosch ignitor and a remapped chip. No need to get complicated and run an aftermarket engine management system or even the Andial splitter setup according to Steve Wong (https://www.911chips.com/engine.htm).
Personally, if I was going to go to the expense of an aftermarket ECU I would go with a VEMS system, do coil on plug, and ditch the air meter. Todd
1989 911 Targa |
