Cam Damaged in Shipping
Well, I just got some really nice Cams in the mail but there wasn't anything protecting the end and it took a hit. Is this still useable? I plan on sending everything off to have it checked and machine if needed. It is a non contact surface. Thoughts?
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
Puny Bird
That sucks but it's just the drive for the adjusting wrench. Did it damage the threads?
Get the cam magnafluxed and checked for straightness, if a pass you're good to go.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
Puny Bird
BTW did that chip off? Cams are quite hard but brittle, not sure but I think some type of cast.
I'd defiantly get it magnafluxed, but I think it wouldn't crack, likely it would just break.
It chipped off as the ends weren't padded at all. You can see a hole in the box where it hit something. Everything else seems fine. Will the machine shop handle the magnaflux process?
Puny Bird
It's a 914 ...
When I buy cams now, I ask the seller to wrap the cams individually and double box them, to survive the abuse that shippers inflict.
When I sent mine off I slid them in two lengths of white pvc pipe and caps. You can get them at Lowe’s or Home Depot for chump change.
Ken 1986 930 2016 R1200RS |
Typo?
Try not, Do or Do not
Although I believe the cams are serviceable (your inspection is important) if this situation bothers you, it is easy to cut the end off the cams, bore and tap them to accept the later bolt and conical washer vs the spring washer /nut design.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
It is really disappointing because just a piece of cardboard at each end would have kept them perfect. They are both really nice low mileage cams.
I guess I will go with them after inspection. Do you think they should be sanded some to remove the rough broken surface?
It's a 914 ...
I've also seen damage like that from using the wrong kind of wrench while torqueing the large nut. Either way, assuming no other damage, I'd dress the area with a file and not worry about it.
That is good to know. Looking at the box, it seems like it occurred during shipping. I took so much care in taking mine off with the Stromski tool only to find they were pitted. Once I got the engine out of the car.. there has been a surprise at every turn.
Of course there are surprises , you are working on a 30 year old car , but best of luck .
Location: behind the redwood curtain, (humboldt county) california
Puny Bird
Likely spell check or because I was using a tablet or my phone and didn't notice the mistake.
Thread Tools | |
Rate This Thread | |
